I’m having issues getting my printer up and running and need a better eye than mine to look at this with me. I’m using a Brother HL-2300D connected via USB. I’ve gotten it to “print” a test page which ends up being a blank page. I’ve tested multiple options in the print settings and nothing is working. Any help on what to try next would be greatly appreciated.
Solved: not an easy one, had to use a driver set from AUR called brlaser v6 while i’m not really good at using AUR a few tutorials on YouTube helped me make and build the package.
Leaving this here in case it helps anyone in the future.
lol, we must have been typing at the same time. Yeah, that’s what i eventually found. I’m not sure about using YAY i did it the hard way i guess. i need to learn how YAY works later but for now i have work to do to get back on schedule (bleh, i hate MUST DO lists).
Ya, I just installed CachyOS KDE Plasma like a few days ago and I had some trouble getting my Xerox B205 working.
It is weird in the System->Printers it hangs when I try to add a printer. But then I luckily found a work around, using a web interface to add prints with CUPS.
