Hi. Is it possible to enable PowerMizer in high-performance mode on Nvidia with Wayland? It’s doable on X11, but on Wayland with Nvidia drivers, that option isn’t available. I’m new to Linux.
Yes: using nvidia-settings -a "[gpu:0]/GpuPowerMizerMode=2"
if it says (Operation not supported).
use sudo
You will need to have a X11 session running first. If you use SDDM or LightDM, then you have a X11 session running already and the commands should work.
Reference: Overclocking nVidia Cards with Headless Linux – ZenCoffee Blog – random notes, guides, and thoughts… (Configuring the card section)
