Obviously, this is a minor annoyance, but already having installed CachyOS in 3 different systems, (and setting up a lazy cache for Pacman on a LXC container) having this issue in only one of them seem weird to me, but I need a little bit of help to start poking around and get logs or config files to pinpoint the culprit here.
I tried setting the wallpaper as simple image and as daily wallpaper provider and both of them are switched back to the default in a timely basis (initially I have only noticed when starting the work day, but today I saw that at the same minute every hour is when the wallpaper reverts itself).
I already have seen two topics kinda related to this (one of them solved as being the folder not accessible at boot time and the other one couldn’t explain a lot more because of language barrier) but those cases applied only at reboot time, so I think it’s quite a different situation right here.
I also changed the lock screen background and that has stayed the same since then.
