I have been compiling some packages and saw that Clang++ uses all of the cores of my CPU rising the temperature, fans etc.
How can I force LLVM to use a maximum number of cores?
I found in LLVM documentation the option:
LLVM_PARALLEL_LINK_JOBS=M
Where should it be specified?
Makepkg.conf or PKGBUILD?
I personally do not mind if it will take longer to compile. I can send the computer (laptop) doing it overnight.
Thanks
