A11
March 31, 2025, 10:12pm
1
naim
April 1, 2025, 3:19am
2
What is “actual workload”? Is it just watching YouTube videos? Note that PREEMPT_RT isn’t meant to be run for “actual workloads”.
and also which version kernel ? 6.14 or before ?
A11
April 4, 2025, 2:22pm
4
v3 (RT Bore and RT Bore LTO) freezes, even just bore optimized on v3.
Gotta do a better job so that those optimizations lasts under actual duty / four monitor set up and not freezes …
actual workloads means actual workloads
100 tabs across 5 browsers, one with three profiles {3 separate window / process}
❯ hyfetch
prince@cachyos-x8664
.+=========================. OS: CachyOS x86_64
:++===++==================- :++- Host: Blade 18 - RZ09-0509 (10.04)
:*++====+++++=============- .==: Kernel: Linux 6.14.0-1-cachyos-server
-*+++=====+***++==========: Uptime: 1 day, 2 hours, 20 mins
=*++++========------------: Packages: 1212 (pacman), 16 (flatpak)
=*+++++=====- ... Shell: zsh 5.9
.+*+++++=-===: .=+++=: Display (BOE0C87): 2560x1600 @ 300 Hz in 18" [Built-in]
:++++=====-==: -*****+ DE: KDE Plasma 6.3.4
:++========-=. .=+**+. WM: KWin (Wayland)
.+==========-. . WM Theme: Breeze
:+++++++====- .--==-. Theme: Breeze (CachyOSNordLightly) [Qt], Breeze-Dark [GTK2], Breeze [GTK3]
:++==========. :+++++++: Icons: breeze-dark [Qt], breeze-dark [GTK2/3/4]
.-===========. =*****+*+ Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
.-===========: .+*****+: Cursor: breeze (24px)
-=======++++:::::::::::::::::::::::::-: .---: Terminal: tilix 1.9.6
:======++++====+++******************=. Terminal Font: CaskaydiaCove Nerd Font Mono (10pt)
:=====+++==========++++++++++++++*- CPU: Intel(R) Core(TM) i9-14900HX (32) @ 5.80 GHz
.====++==============++++++++++*- GPU 1: NVIDIA GeForce RTX 4090 Laptop GPU [Discrete]
.===+==================+++++++: GPU 2: Intel Raptor Lake-S UHD Graphics @ 1.65 GHz [Integrated]
.-=======================+++: Memory: 12.48 GiB / 30.97 GiB (40%)
.......................... Swap: 0 B / 62.97 GiB (0%)
Disk (/): 122.02 GiB / 1.82 TiB (7%) - xfs
Local IP (enp46s0): 1x.1x.1x4.159/22
Battery (Blade): 100% [AC Connected]
Locale: en_US.UTF-8
A11
April 4, 2025, 2:31pm
5
I have been here when nobody was.
make full proof kernels naim.
hk does not has sufficient space to send rockets to mars.
I m a mainlander.
naim
April 4, 2025, 4:07pm
6
Those workloads doesn’t fit the usecase of PREEMPT_RT, instability is to be expected. Weird that you’re seeing freezes in BORE kernel too, since that is pretty much identical to default.
Without any logs, there’s nothing I can do. There’s also not much that I can do as a downstream maintainer. Test the Arch kernel, if it freezes there then it’s upstream’s problem.
sudo pacman -U https://archive.archlinux.org/packages/l/linux/linux-6.14.arch1-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/l/linux-headers/linux-headers-6.14.arch1-1-x86_64.pkg.tar.zst
