I just installed obs-studio for screen recording, but I can’t record anything, the screen shows up in the preview. Also there is only the software encoder x264 available. I have tried searching but there are so many posts I can’t find anything useful.
I just want to record my screen, is there an alternative?
20:23:51.573: ---------------------------------
20:23:51.574: [x264 encoder: 'simple_video_recording'] preset: veryfast
20:23:51.574: [x264 encoder: 'simple_video_recording'] profile: high
20:23:51.574: [x264 encoder: 'simple_video_recording'] settings:
20:23:51.574: rate_control: CRF
20:23:51.574: bitrate: 0
20:23:51.574: buffer size: 0
20:23:51.574: crf: 23
20:23:51.574: fps_num: 60
20:23:51.574: fps_den: 1
20:23:51.574: width: 1920
20:23:51.574: height: 1080
20:23:51.574: keyint: 250
20:23:51.574:
20:23:51.581: libfdk_aac encoder created
20:23:51.581: libfdk_aac bitrate: 192, channels: 2
20:23:51.584: ==== Recording Start ===============================================
20:23:51.584: [ffmpeg muxer: 'simple_file_output'] Writing file '/home/csaba/Videos/obs/2024-10-27_20-23-51.mp4'...
20:24:04.586: [ffmpeg muxer: 'simple_file_output'] os_process_pipe_write for info structure failed
20:24:04.586: [ffmpeg muxer: 'simple_file_output'] ffmpeg-mux: Couldn't initialize muxer
20:24:04.586:
20:24:04.586: [ffmpeg muxer: 'simple_file_output'] Output of file '/home/csaba/Videos/obs/2024-10-27_20-23-51.mp4' stopped
20:24:04.586: Output 'simple_file_output': stopping
20:24:04.586: Output 'simple_file_output': Total frames output: 742
20:24:04.586: Output 'simple_file_output': Total drawn frames: 781
20:24:04.587: ==== Recording Stop ================================================
20:24:04.600: libfdk_aac encoder destroyed
My hw
CPU:
Info: model: AMD Ryzen 7 7730U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000F
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4517 min/max: 400/4546 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4517 2: 4517 3: 4517
4: 4517 5: 4517 6: 4517 7: 4517 8: 4517 9: 4517 10: 4517 11: 4517 12: 4517
13: 4517 14: 4517 15: 4517 16: 4517 bogomips: 63881
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: retbleed status: Not affected
Type: spec_rstack_overflow mitigation: Safe RET
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW;
STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Lenovo
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15e7 class-ID: 0300 temp: 48.0 C
Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 30c9:00a7
class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
compositors: 1: gnome-shell 2: SurfaceFlinger driver: gpu: amdgpu
display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1552 built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi
wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.5-cachyos1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
renoir LLVM 18.1.8 DRM 3.59 6.11.5-2-cachyos-bore-lto)
device-ID: 1002:15e7 memory: 1.95 GiB unified: no display-ID: :0.0
vainfo
Trying display: wayland
vainfo: VA-API version: 1.22 (libva 2.22.0)
vainfo: Driver version: Mesa Gallium driver 24.2.5-cachyos1.2 for AMD Radeon Graphics (radeonsi, renoir, LLVM 18.1.8, DRM 3.59, 6.11.5-2-cachyos-bore-lto)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
