Nvidia external monitor not discovered properly after update
I’ve done pacman -Syu this morning followed by a restart as recommended by the pop-up (updated kernel) and then I was greeted with only the integrated laptop display showing up. Upon connection/disconnection the system asks for how I want the displays (mirrored, extended etc) but in the settings the second monitor does not show up. Tried disconnecting, connecting, etc and searched for a fix but couldn’t find one. Can I manually downgrade the kernel and driver?
I take it - you joined the same club:
… ? What does it say - if you enter the following command?
uname -r
Also don’t you have LTS - as alternative?
uname -r
7.0.5-2-cachyos
Update…
my problem got fixed…:heart:
