No signal via USB-C to DisplayPort
Hello, I recently purchased a new DELL G2724D monitor. When I connected it to my Lenovo Legion 5 15ARH05 laptop via HDMI 2.0, everything worked fine, and the display runs at 144Hz.
The monitor came with a USB-C to DisplayPort cable, which I used to connect the monitor instead of HDMI. Unfortunately, I get a message saying there is no signal from the device. The laptop has a USB-C port with DP 1.2 support, and the monitor supports DP 1.4, but they should be backward compatible.
In the monitor settings, it’s not possible to manually switch to DP 1.2. I’ve read that the graphics card should handle this automatically, but it appears it’s not doing so. How can I force the graphics card to output a signal through the USB-C port?
OS: CachyOS Linux x86_64
Host: 82B1 (Lenovo Legion 5 15ARH05H)
Kernel: Linux 6.12.7-2-cachyos
Display (DELL G2724D): 2560x1440 @ 144 Hz (as 2134x]
DE: KDE Plasma 6.2.4
WM: KWin (Wayland)
CPU: AMD Ryzen 7 4800H (16) @ 2.90 GHz
GPU: NVIDIA GeForce GTX 1660 Ti Mobile [Discrete]
Memory: 5.14 GiB / 15.49 GiB (33%)
Thank you in advance for your help.
Best regards.
