Need assistance to OC my GPU
Hello there, i’m not a technical user.
I didn’t managed to follow this tutorial correcly :
So i tried with gwe ( green with envy ) and i could apply settings only on the wattage. The oc and the fan control option return me a “error applying option”
Then i tried with corectrl but the only the cpu appear.
And after checking this NVIDIA/Tips and tricks - ArchWiki i didnt wanted to do anything stupid.
So here i am asking for help:
At the step 2.2 of the tutorial i have this error message.
[root@cachy NVIDIA]# source /root/NVIDIA/venv/bin/activate.fish
-bash: /root/NVIDIA/venv/bin/activate.fish: ligne 4: erreur de syntaxe près du symbole inattendu « -d »
-bash: /root/NVIDIA/venv/bin/activate.fish: ligne 4: `function deactivate  -d "Exit virtual environment and return to normal shell environment"'
In the /activate.fish ligne 4 its written
# This file must be used with "source <venv>/bin/activate.fish" *from fish*
# (https://fishshell.com/). You cannot run it directly.
to me its chinesse but if someone have time, knowledge and kindness to help me me and my potato gpu would appreciate !
EDIT:
i’ve try the method 8.1.3 from the arch wiki. i type desired offclock in nvidia settings (nothing happend)
then tried to save them with this command but i had this return
nvidia-settings -a "GPUGraphicsClockOffset[performance_level]=offset"
ERROR: Error parsing assignment 'GPUGraphicsClockOffset[performance_level]=offset' (Malformed display device identification).
same issue when i try this one
nvidia-settings -a "GPUGraphicsClockOffset[level]=100"
just an update:
i’ve managed to Overclock under X11 by doing this :
Set
needs_root_rights = yes
in the file /etc/X11/Xwrapper.config
as stated here Cannot overclock gpu after nvidia upgrade / Kernel & Hardware / Arch Linux Forums and it works.
How bad/dangerous is it to run xorg as root ?
i’ll find a way to make the overclock permanent anyways
