My system crashed
I was using normally Cachy OS with systemd-boot and xfce4 and disc protetected (file format btrfs)
I wanted to install mozjpeg
yay -S mozjpeg
There was only 1 AUR and i chose it
Mozjpeg had installed from his source code. Terminal was asked to me there is an 2 package and said do you want delete this package and install this. And i said yes
(First was a jpeg library as i remind. And second was mozjpeg’s library)
I did continue to use PC a time. And i stand up did some job when i sit there was a black screen and when i try touchpad the mouse icon was for one time existing and for one time non existing (I mean when i use my finger on touchpad mouse icon was coming but not fully coming and going and coming and going…)
After this i shut down PC and started Cachy OS. The first disc encryption part started and worked well and some things had worked. But after them my monitor gived me a black screen with a bipping _
It was like a terminal screen but everything clean and only _
I waited some time and restarted PC with fallback option.
It too non worked. Same screen.
And started again normal Cachy OS waited more than 10 minutes. No respond it was waiting only black screen.
I will send logs. Wait some…
What should i send? There is a file named private on @log and on @log there is boot.log pacman.log and Xorg.0.log etc
Dolphin doesnt work well i cant see on terminal my phone it may be long
Edit: New boot.log
------------ Thu Oct 03 07:53:49 +03 2024 ------------
:: running hook [encrypt]
:: mounting 'UUID=bde10155-883f-4b5a-8f95-219d1eb077bb' on real root
:: running late hook [plymouth]
:: running cleanup hook [udev]
e[!pe]104ae[?7h
Welcome to e[38;2;23;147;209mCachyOSe[0m!
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/dirmngre[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/gettye[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/gpg-agente[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/gpg-agent-browsere[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/gpg-agent-extrae[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/gpg-agent-sshe[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/keyboxde[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/modprobee[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mEncrypted Volume Units Service Slicee[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/systemd-fscke[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/systemd-zram-setupe[0m.
[e[0;32m  OK  e[0m] Created slice e[0;1;39mUser and Session Slicee[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mForward Password Requests to Wall Directory Watche[0m.
[e[0;32m  OK  e[0m] Set up automount e[0;1;39mArbitrary Executable File Formats File System Automount Pointe[0m.
         Expecting device e[0;1;39m/dev/disk/by-uuid/3BCE-8869e[0m...
         Expecting device e[0;1;39m/dev/disk/by-uuid/5a23945c-2ef2-4ca3-af4e-dfce3582841de[0m...
         Expecting device e[0;1;39m/dev/mapper/luks-5a23945c-2ef2-4ca3-af4e-dfce3582841de[0m...
         Expecting device e[0;1;39m/dev/zram0e[0m...
[e[0;32m  OK  e[0m] Reached target e[0;1;39mLogin Promptse[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mLocal Integrity Protected Volumese[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mRemote File Systemse[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mSlice Unitse[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mLocal Verity Protected Volumese[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mDevice-mapper event daemon FIFOse[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mLVM2 poll daemon sockete[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mProcess Core Dump Sockete[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mCredential Encryption/Decryptione[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mJournal Socket (/dev/log)e[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mJournal Socketse[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mudev Control Sockete[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mudev Kernel Sockete[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mUser Database Manager Sockete[0m.
         Mounting e[0;1;39mHuge Pages File Systeme[0m...
         Mounting e[0;1;39mPOSIX Message Queue File Systeme[0m...
         Mounting e[0;1;39mKernel Debug File Systeme[0m...
         Mounting e[0;1;39mKernel Trace File Systeme[0m...
         Starting e[0;1;39mMonitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress pollinge[0m...
         Starting e[0;1;39mLoad Kernel Module configfse[0m...
         Starting e[0;1;39mLoad Kernel Module dm_mode[0m...
         Starting e[0;1;39mLoad Kernel Module drme[0m...
         Starting e[0;1;39mLoad Kernel Module fusee[0m...
         Starting e[0;1;39mLoad Kernel Module loope[0m...
         Starting e[0;1;39mJournal Servicee[0m...
         Starting e[0;1;39mLoad Kernel Modulese[0m...
         Starting e[0;1;39mRemount Root and Kernel File Systemse[0m...
         Starting e[0;1;39mCreate Static Device Nodes in /dev gracefullye[0m...
         Starting e[0;1;39mLoad udev Rules from Credentialse[0m...
         Starting e[0;1;39mColdplug All udev Devicese[0m...
         Starting e[0;1;39mVirtual Console Setupe[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad Kernel Module configfse[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad Kernel Module dm_mode[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad Kernel Module drme[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad Kernel Module fusee[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad Kernel Module loope[0m.
         Mounting e[0;1;39mFUSE Control File Systeme[0m...
         Mounting e[0;1;39mKernel Configuration File Systeme[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad Kernel Modulese[0m.
         Starting e[0;1;39mApply Kernel Variablese[0m...
[e[0;32m  OK  e[0m] Mounted e[0;1;39mKernel Trace File Systeme[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39mPOSIX Message Queue File Systeme[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39mKernel Debug File Systeme[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39mFUSE Control File Systeme[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39mKernel Configuration File Systeme[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39mHuge Pages File Systeme[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad udev Rules from Credentialse[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mJournal Servicee[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mVirtual Console Setupe[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mColdplug All udev Devicese[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mApply Kernel Variablese[0m.
         Starting e[0;1;39mCLI Netfilter Managere[0m...
         Starting e[0;1;39mUser Database Managere[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mRemount Root and Kernel File Systemse[0m.
         Starting e[0;1;39mLoad/Save OS Random Seede[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mUser Database Managere[0m.
[e[0;1;31mFAILEDe[0m] Failed to start e[0;1;39mCLI Netfilter Managere[0m.
See 'systemctl status ufw.service' for details.
[e[0;32m  OK  e[0m] Finished e[0;1;39mCreate Static Device Nodes in /dev gracefullye[0m.
         Starting e[0;1;39mCreate System Userse[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad/Save OS Random Seede[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mMonitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress pollinge[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mCreate System Userse[0m.
         Starting e[0;1;39mCreate Static Device Nodes in /deve[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mCreate Static Device Nodes in /deve[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mPreparation for Local File Systemse[0m.
         Starting e[0;1;39mRule-based Manager for Device Events and Filese[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mRule-based Manager for Device Events and Filese[0m.
         Starting e[0;1;39mShow Plymouth Boot Screene[0m...
[e[0;32m  OK  e[0m] Created slice e[0;1;39mSlice /system/systemd-backlighte[0m.
         Starting e[0;1;39mLoad/Save Screen Backlight Brightness of backlight:intel_backlighte[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mLoad/Save Screen Backlight Brightness of backlight:intel_backlighte[0m.
[e[0;32m  OK  e[0m] Stopped e[0;1;39mVirtual Console Setupe[0m.
         Stopping e[0;1;39mVirtual Console Setupe[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mShow Plymouth Boot Screene[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mForward Password Requests to Plymouth Directory Watche[0m.
[e[0;32m  OK  e[0m] Found device e[0;1;39mST9500325AS 4e[0m.
         Starting e[0;1;39mFile System Check on /dev/disk/by-uuid/3BCE-8869e[0m...
[e[0;32m  OK  e[0m] Found device e[0;1;39mST9500325AS roote[0m.
         Starting e[0;1;39mCryptography Setup for luks-5a23945c-2ef2-4ca3-af4e-dfce3582841de[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mCryptography Setup for luks-5a23945c-2ef2-4ca3-af4e-dfce3582841de[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mBlock Device Preparation for /dev/mapper/luks-5a23945c-2ef2-4ca3-af4e-dfce3582841de[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mLocal Encrypted Volumese[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mFile System Check on /dev/disk/by-uuid/3BCE-8869e[0m.
         Mounting e[0;1;39m/boote[0m...
         Mounting e[0;1;39m/homee[0m...
         Mounting e[0;1;39m/roote[0m...
         Mounting e[0;1;39m/srve[0m...
         Mounting e[0;1;39m/var/cachee[0m...
         Mounting e[0;1;39m/var/loge[0m...
         Mounting e[0;1;39m/var/tmpe[0m...
[e[0;32m  OK  e[0m] Mounted e[0;1;39m/srve[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39m/var/loge[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39m/var/cachee[0m.
         Starting e[0;1;39mFlush Journal to Persistent Storagee[0m...
[e[0;1;31mFAILEDe[0m] Failed to mount e[0;1;39m/boote[0m.
See 'systemctl status boot.mount' for details.
[e[0;1;38:5:185mDEPENDe[0m] Dependency failed for e[0;1;39mLocal File Systemse[0m.
[e[0;32m  OK  e[0m] Stopped e[0;1;39mForward Password Requests to Wall Directory Watche[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mTimer Unitse[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mBoot Entries Service Sockete[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mSystem Extension Image Managemente[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mPath Unitse[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mSocket Unitse[0m.
         Starting e[0;1;39mRebuild Dynamic Linker Cachee[0m...
         Starting e[0;1;39mTell Plymouth To Write Out Runtime Datae[0m...
         Starting e[0;1;39mUpdate Boot Loader Random Seede[0m...
[e[0;32m  OK  e[0m] Mounted e[0;1;39m/var/tmpe[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39m/roote[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mEmergency Shelle[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mEmergency Modee[0m.
[e[0;32m  OK  e[0m] Mounted e[0;1;39m/homee[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mTell Plymouth To Write Out Runtime Datae[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mUpdate Boot Loader Random Seede[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mFlush Journal to Persistent Storagee[0m.
         Starting e[0;1;39mCreate System Files and Directoriese[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mCreate System Files and Directoriese[0m.
         Starting e[0;1;39mRebuild Journal Cataloge[0m...
         Starting e[0;1;39mRecord System Boot/Shutdown in UTMPe[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mRecord System Boot/Shutdown in UTMPe[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mRebuild Journal Cataloge[0m.
from pacman.log (New)
[2024-10-02T15:27:05+0300] [PACMAN] Running 'pacman -S mozjpeg'
[2024-10-02T15:27:32+0300] [PACMAN] Running 'pacman -S --config /etc/pacman.conf -- extra/nasm extra/cmake'
[2024-10-02T15:27:41+0300] [ALPM] transaction started
[2024-10-02T15:27:41+0300] [ALPM] installed nasm (2.16.03-1)
[2024-10-02T15:27:41+0300] [ALPM] installed cppdap (1.58.0-2)
[2024-10-02T15:27:41+0300] [ALPM] installed jsoncpp (1.9.6-3)
[2024-10-02T15:27:41+0300] [ALPM] installed rhash (1.4.4-1)
[2024-10-02T15:27:41+0300] [ALPM] installed cmake (3.30.4-1)
[2024-10-02T15:27:45+0300] [ALPM] transaction completed
[2024-10-02T15:27:45+0300] [ALPM] running '30-systemd-update.hook'...
[2024-10-02T15:27:45+0300] [ALPM] running '30-update-mime-database.hook'...
[2024-10-02T15:27:46+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-10-02T15:27:47+0300] [ALPM] running 'update-desktop-database.hook'...
[2024-10-02T15:27:47+0300] [PACMAN] Running 'pacman -D -q --asdeps --config /etc/pacman.conf -- nasm cmake'
[2024-10-02T15:29:57+0300] [PACMAN] Running 'pacman -U --config /etc/pacman.conf -- /home/salih/.cache/yay/mozjpeg/mozjpeg-4.1.5-1-x86_64.pkg.tar.zst'
[2024-10-02T15:37:07+0300] [ALPM] transaction started
[2024-10-02T15:37:12+0300] [ALPM] removed libjpeg-turbo (3.0.4-1)
[2024-10-02T15:37:12+0300] [ALPM] installed mozjpeg (4.1.5-1)
[2024-10-02T15:37:13+0300] [ALPM] transaction completed
[2024-10-02T15:37:13+0300] [ALPM] running '30-systemd-update.hook'...
[2024-10-02T15:37:17+0300] [PACMAN] Running 'pacman -D -q --asexplicit --config /etc/pacman.conf -- mozjpeg'
[2024-10-02T15:37:52+0300] [PACMAN] Running 'pacman -S jpegoptim'
[2024-10-02T15:37:55+0300] [ALPM] transaction started
[2024-10-02T15:37:55+0300] [ALPM] installed jpegoptim (1.5.5-3)
[2024-10-02T15:37:55+0300] [ALPM] transaction completed
[2024-10-02T15:37:55+0300] [ALPM] running '30-systemd-update.hook'...
[2024-10-03T07:54:33+0300] [PACMAN] Running 'pacman -Syu'
[2024-10-03T07:54:33+0300] [PACMAN] synchronizing package lists
Xorg.0.log
[    56.124] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    56.124] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    56.124] (==) No Layout section.  Using the first Screen section.
[    56.124] (==) No screen section available. Using defaults.
[    56.124] (**) |-->Screen "Default Screen Section" (0)
[    56.124] (**) |   |-->Monitor "<default monitor>"
[    56.124] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    56.124] (**) Allowing byte-swapped clients
[    56.124] (==) Automatically adding devices
[    56.124] (==) Automatically enabling devices
[    56.124] (==) Automatically adding GPU devices
[    56.124] (==) Automatically binding GPU devices
[    56.124] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    56.124] (WW) The directory "/usr/share/fonts/misc" does not exist.
[    56.124] 	Entry deleted from font path.
[    56.124] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[    56.124] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[    56.124] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[    56.124] 	(Run 'mkfontdir' on "/usr/share/fonts/OTF").
[    56.124] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    56.124] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    56.124] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    56.124] (==) FontPath set to:
[    56.124] (==) ModulePath set to "/usr/lib/xorg/modules"
[    56.124] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    56.124] (II) Module ABI versions:
[    56.124] 	X.Org ANSI C Emulation: 0.4
[    56.124] 	X.Org Video Driver: 25.2
[    56.124] 	X.Org XInput driver : 24.4
[    56.124] 	X.Org Server Extension : 10.0
[    56.125] (++) using VT number 7
[    56.125] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    56.126] (II) xfree86: Adding drm device (/dev/dri/card1)
[    56.126] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[    56.126] (II) xfree86: Adding drm device (/dev/dri/card0)
[    56.126] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[    56.134] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    56.137] (--) PCI:*(0@0:2:0) 8086:0166:144d:c0d7 rev 9, Mem @ 0xf1000000/4194304, 0xe0000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[    56.137] (--) PCI: (1@0:0:0) 10de:1140:144d:c0d7 rev 161, Mem @ 0xf0000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128
[    56.137] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    56.137] (II) LoadModule: "glx"
[    56.137] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[    56.142] (II) Module glx: vendor="NVIDIA Corporation"
[    56.142] 	compiled for 4.0.2, module version = 1.0.0
[    56.142] 	Module class: X.Org Server Extension
[    56.142] (II) NVIDIA GLX Module  390.157  Wed Oct 12 09:19:15 UTC 2022
[    56.142] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[    56.142] 	loading driver: nvidia
[    56.142] (==) Matched intel as autoconfigured driver 0
[    56.142] (==) Matched nvidia as autoconfigured driver 1
[    56.142] (==) Matched nouveau as autoconfigured driver 2
[    56.142] (==) Matched nv as autoconfigured driver 3
[    56.142] (==) Matched modesetting as autoconfigured driver 4
[    56.142] (==) Matched fbdev as autoconfigured driver 5
[    56.142] (==) Matched vesa as autoconfigured driver 6
[    56.142] (==) Assigned the driver to the xf86ConfigLayout
[    56.142] (II) LoadModule: "intel"
[    56.142] (WW) Warning, couldn't open module intel
[    56.142] (EE) Failed to load module "intel" (module does not exist, 0)
[    56.142] (II) LoadModule: "nvidia"
[    56.142] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    56.143] (II) Module nvidia: vendor="NVIDIA Corporation"
[    56.143] 	compiled for 4.0.2, module version = 1.0.0
[    56.143] 	Module class: X.Org Video Driver
[    56.143] (II) LoadModule: "nouveau"
[    56.143] (WW) Warning, couldn't open module nouveau
[    56.143] (EE) Failed to load module "nouveau" (module does not exist, 0)
[    56.143] (II) LoadModule: "nv"
[    56.143] (WW) Warning, couldn't open module nv
[    56.143] (EE) Failed to load module "nv" (module does not exist, 0)
[    56.143] (II) LoadModule: "modesetting"
[    56.143] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    56.174] (II) Module modesetting: vendor="X.Org Foundation"
[    56.174] 	compiled for 1.21.1.13, module version = 1.21.1
[    56.174] 	Module class: X.Org Video Driver
[    56.174] 	ABI class: X.Org Video Driver, version 25.2
[    56.174] (II) LoadModule: "fbdev"
[    56.174] (WW) Warning, couldn't open module fbdev
[    56.174] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    56.174] (II) LoadModule: "vesa"
[    56.174] (WW) Warning, couldn't open module vesa
[    56.174] (EE) Failed to load module "vesa" (module does not exist, 0)
[    56.174] (II) NVIDIA dlloader X Driver  390.157  Wed Oct 12 09:21:41 UTC 2022
[    56.175] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    56.175] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    56.182] (II) modeset(0): using drv /dev/dri/card0
[    56.182] (II) modeset(G0): using drv /dev/dri/card1
[    56.183] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    56.183] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    56.183] (==) modeset(0): RGB weight 888
[    56.183] (==) modeset(0): Default visual is TrueColor
[    56.183] (II) Loading sub module "glamoregl"
[    56.183] (II) LoadModule: "glamoregl"
[    56.183] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    56.189] (II) Module glamoregl: vendor="X.Org Foundation"
[    56.189] 	compiled for 1.21.1.13, module version = 1.0.1
[    56.189] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    56.212] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 4000 (IVB GT2)
[    56.212] (II) modeset(0): glamor initialized
[    56.212] (==) modeset(0): VariableRefresh: disabled
[    56.212] (==) modeset(0): AsyncFlipSecondaries: disabled
[    56.212] (II) modeset(0): Output LVDS-1 has no monitor section
[    56.213] (II) modeset(0): Output VGA-1 has no monitor section
[    56.214] (II) modeset(0): Output HDMI-1 has no monitor section
[    56.219] (II) modeset(0): Output DP-1 has no monitor section
[    56.219] (II) modeset(0): EDID for output LVDS-1
[    56.219] (II) modeset(0): Printing probed modes for output LVDS-1
[    56.219] (II) modeset(0): Modeline "1366x768"x60.1   70.70  1366 1414 1446 1486  768 770 775 792 -hsync -vsync (47.6 kHz eP)
[    56.219] (II) modeset(0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[    56.219] (II) modeset(0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[    56.219] (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[    56.219] (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[    56.219] (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    56.219] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    56.219] (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    56.219] (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    56.219] (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    56.219] (II) modeset(0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[    56.219] (II) modeset(0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[    56.219] (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[    56.219] (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[    56.219] (II) modeset(0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[    56.219] (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    56.219] (II) modeset(0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[    56.219] (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    56.219] (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[    56.219] (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[    56.219] (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    56.219] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    56.219] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    56.219] (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    56.219] (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    56.219] (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[    56.219] (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[    56.219] (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    56.220] (II) modeset(0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[    56.220] (II) modeset(0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[    56.220] (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    56.220] (II) modeset(0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[    56.220] (II) modeset(0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[    56.220] (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    56.220] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    56.220] (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[    56.220] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    56.220] (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    56.220] (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    56.220] (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    56.220] (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    56.220] (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    56.220] (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    56.220] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    56.220] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    56.220] (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    56.220] (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    56.220] (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    56.220] (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    56.220] (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    56.220] (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    56.220] (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    56.220] (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    56.220] (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    56.220] (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    56.220] (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    56.220] (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    56.220] (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    56.220] (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    56.221] (II) modeset(0): EDID for output VGA-1
[    56.222] (II) modeset(0): EDID for output HDMI-1
[    56.227] (II) modeset(0): EDID for output DP-1
[    56.227] (II) modeset(0): Output LVDS-1 connected
[    56.227] (II) modeset(0): Output VGA-1 disconnected
[    56.227] (II) modeset(0): Output HDMI-1 disconnected
[    56.227] (II) modeset(0): Output DP-1 disconnected
[    56.227] (II) modeset(0): Using exact sizes for initial modes
[    56.227] (II) modeset(0): Output LVDS-1 using initial mode 1366x768 +0+0
[    56.227] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    56.227] (==) modeset(0): DPI set to (96, 96)
[    56.227] (II) Loading sub module "fb"
[    56.227] (II) LoadModule: "fb"
[    56.227] (II) Module "fb" already built-in
[    56.227] (II) modeset(G0): Using 24bpp hw front buffer with 32bpp shadow
[    56.227] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    56.228] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[    56.228] (==) modeset(G0): RGB weight 888
[    56.228] (==) modeset(G0): Default visual is TrueColor
[    56.228] (**) modeset(G0): Cannot use glamor with 24bpp packed fb
[    56.228] (II) modeset(G0): ShadowFB: preferred YES, enabled FORCE
[    56.228] (II) modeset(G0): Double-buffered shadow updates: off
[    56.228] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    56.228] (==) modeset(G0): DPI set to (96, 96)
[    56.228] (II) Loading sub module "fb"
[    56.228] (II) LoadModule: "fb"
[    56.228] (II) Module "fb" already built-in
[    56.228] (II) Loading sub module "shadow"
[    56.228] (II) LoadModule: "shadow"
[    56.228] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    56.228] (II) Module shadow: vendor="X.Org Foundation"
[    56.228] 	compiled for 1.21.1.13, module version = 1.1.0
[    56.228] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    56.249] (==) modeset(0): Backing store enabled
[    56.249] (==) modeset(0): Silken mouse enabled
[    56.283] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    56.283] (==) modeset(0): DPMS enabled
[    56.283] (II) modeset(0): [DRI2] Setup complete
[    56.283] (II) modeset(0): [DRI2]   DRI driver: crocus
[    56.283] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[    56.284] (==) modeset(G0): Backing store enabled
[    56.284] (==) modeset(G0): Silken mouse enabled
[    56.284] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[    56.284] (==) modeset(G0): DPMS enabled
[    56.284] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[    56.284] (II) Initializing extension Generic Event Extension
[    56.284] (II) Initializing extension SHAPE
[    56.284] (II) Initializing extension MIT-SHM
[    56.285] (II) Initializing extension XInputExtension
[    56.285] (II) Initializing extension XTEST
[    56.285] (II) Initializing extension BIG-REQUESTS
[    56.285] (II) Initializing extension SYNC
[    56.285] (II) Initializing extension XKEYBOARD
[    56.285] (II) Initializing extension XC-MISC
[    56.285] (II) Initializing extension SECURITY
[    56.286] (II) Initializing extension XFIXES
[    56.286] (II) Initializing extension RENDER
[    56.286] (II) Initializing extension RANDR
[    56.286] (II) Initializing extension COMPOSITE
[    56.286] (II) Initializing extension DAMAGE
[    56.286] (II) Initializing extension MIT-SCREEN-SAVER
[    56.286] (II) Initializing extension DOUBLE-BUFFER
[    56.286] (II) Initializing extension RECORD
[    56.287] (II) Initializing extension DPMS
[    56.287] (II) Initializing extension Present
[    56.287] (II) Initializing extension DRI3
[    56.287] (II) Initializing extension X-Resource
[    56.287] (II) Initializing extension XVideo
[    56.287] (II) Initializing extension XVideo-MotionCompensation
[    56.287] (II) Initializing extension XFree86-VidModeExtension
[    56.287] (II) Initializing extension XFree86-DGA
[    56.287] (II) Initializing extension XFree86-DRI
[    56.287] (II) Initializing extension DRI2
[    56.288] (II) Initializing extension GLX
[    56.288] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[    56.288] (II) modeset(G0): Damage tracking initialized
[    56.288] (II) modeset(0): Damage tracking initialized
[    56.288] (II) modeset(0): Setting screen physical size to 361 x 203
[    56.348] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    56.348] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    56.348] (**) Power Button: Applying InputClass "system-keyboard"
[    56.348] (II) LoadModule: "libinput"
[    56.348] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    56.351] (II) Module libinput: vendor="X.Org Foundation"
[    56.351] 	compiled for 1.21.1.13, module version = 1.4.0
[    56.351] 	Module class: X.Org XInput Driver
[    56.351] 	ABI class: X.Org XInput driver, version 24.4
[    56.351] (II) Using input driver 'libinput' for 'Power Button'
[    56.351] (**) Power Button: always reports core events
[    56.351] (**) Option "Device" "/dev/input/event2"
[    56.353] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    56.353] (II) event2  - Power Button: device is a keyboard
[    56.353] (II) event2  - Power Button: device removed
[    56.353] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    56.353] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    56.353] (**) Option "xkb_layout" "tr"
[    56.354] (**) Option "xkb_variant" "f"
[    56.376] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    56.376] (II) event2  - Power Button: device is a keyboard
[    56.377] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[    56.377] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    56.377] (**) Video Bus: Applying InputClass "system-keyboard"
[    56.377] (II) Using input driver 'libinput' for 'Video Bus'
[    56.377] (**) Video Bus: always reports core events
[    56.377] (**) Option "Device" "/dev/input/event5"
[    56.378] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[    56.378] (II) event5  - Video Bus: device is a keyboard
[    56.378] (II) event5  - Video Bus: device removed
[    56.385] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input6/event5"
[    56.385] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    56.385] (**) Option "xkb_layout" "tr"
[    56.385] (**) Option "xkb_variant" "f"
[    56.386] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[    56.386] (II) event5  - Video Bus: device is a keyboard
[    56.387] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[    56.387] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    56.387] (**) Video Bus: Applying InputClass "system-keyboard"
[    56.387] (II) Using input driver 'libinput' for 'Video Bus'
[    56.387] (**) Video Bus: always reports core events
[    56.387] (**) Option "Device" "/dev/input/event4"
[    56.389] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[    56.389] (II) event4  - Video Bus: device is a keyboard
[    56.389] (II) event4  - Video Bus: device removed
[    56.403] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3a/LNXVIDEO:00/input/input5/event4"
[    56.403] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    56.403] (**) Option "xkb_layout" "tr"
[    56.403] (**) Option "xkb_variant" "f"
[    56.405] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[    56.405] (II) event4  - Video Bus: device is a keyboard
[    56.406] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    56.406] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    56.406] (**) Power Button: Applying InputClass "system-keyboard"
[    56.406] (II) Using input driver 'libinput' for 'Power Button'
[    56.406] (**) Power Button: always reports core events
[    56.406] (**) Option "Device" "/dev/input/event1"
[    56.407] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    56.407] (II) event1  - Power Button: device is a keyboard
[    56.407] (II) event1  - Power Button: device removed
[    56.407] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[    56.407] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    56.407] (**) Option "xkb_layout" "tr"
[    56.407] (**) Option "xkb_variant" "f"
[    56.408] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    56.408] (II) event1  - Power Button: device is a keyboard
[    56.409] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    56.409] (II) No input driver specified, ignoring this device.
[    56.409] (II) This device may have been added with another device file.
[    56.410] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event9)
[    56.410] (II) No input driver specified, ignoring this device.
[    56.410] (II) This device may have been added with another device file.
[    56.411] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event10)
[    56.411] (II) No input driver specified, ignoring this device.
[    56.411] (II) This device may have been added with another device file.
[    56.411] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event8)
[    56.412] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    56.412] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    56.412] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    56.412] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    56.412] (**) AT Translated Set 2 keyboard: always reports core events
[    56.412] (**) Option "Device" "/dev/input/event3"
[    56.413] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    56.413] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    56.414] (II) event3  - AT Translated Set 2 keyboard: device removed
[    56.414] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[    56.414] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[    56.414] (**) Option "xkb_layout" "tr"
[    56.414] (**) Option "xkb_variant" "f"
[    56.415] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    56.415] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    56.417] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event6)
[    56.417] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[    56.417] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[    56.417] (**) ETPS/2 Elantech Touchpad: always reports core events
[    56.417] (**) Option "Device" "/dev/input/event6"
[    56.418] (II) event6  - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[    56.419] (II) event6  - ETPS/2 Elantech Touchpad: device is a touchpad
[    56.419] (II) event6  - ETPS/2 Elantech Touchpad: device removed
[    56.438] (II) libinput: ETPS/2 Elantech Touchpad: Step value 0 was provided, libinput Fallback acceleration function is used.
[    56.438] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event6"
[    56.438] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 11)
[    56.439] (**) Option "AccelerationScheme" "none"
[    56.440] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[    56.440] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[    56.440] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[    56.441] (II) event6  - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[    56.442] (II) event6  - ETPS/2 Elantech Touchpad: device is a touchpad
[    56.443] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[    56.443] (II) No input driver specified, ignoring this device.
[    56.443] (II) This device may have been added with another device file.
[    56.444] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[    56.444] (II) No input driver specified, ignoring this device.
[    56.444] (II) This device may have been added with another device file.
[    56.711] (II) event2  - Power Button: device removed
[    56.711] (II) event5  - Video Bus: device removed
[    56.717] (II) event4  - Video Bus: device removed
[    56.723] (II) event1  - Power Button: device removed
[    56.723] (II) event3  - AT Translated Set 2 keyboard: device removed
[    56.723] (II) event6  - ETPS/2 Elantech Touchpad: device removed
[    56.736] (II) UnloadModule: "libinput"
[    56.820] (II) Server terminated successfully (0). Closing log file.
lightdm.log
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.32.0, UID=0 PID=932
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: Using cross-namespace EXTERNAL authentication (this will deadlock if server is GDBus < 2.73.3)
[+0.00s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.00s] DEBUG: Monitoring logind for seats
[+0.00s] DEBUG: New seat added from logind: seat0
[+0.00s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.00s] DEBUG: Seat seat0 has property CanMultiSession=no
[+0.00s] DEBUG: Seat seat0: Starting
[+0.00s] DEBUG: Seat seat0: Creating greeter session
[+0.00s] DEBUG: Seat seat0: Creating display server of type x
[+0.01s] DEBUG: Using VT 7
[+0.01s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.01s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.01s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.01s] DEBUG: XServer 0: Launching X Server
[+0.01s] DEBUG: Launching process 939: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.01s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.01s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.01s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.01s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.37s] DEBUG: Got signal 10 from process 939
[+0.37s] DEBUG: XServer 0: Got signal from X server :0
[+0.37s] DEBUG: XServer 0: Connecting to XServer :0
[+0.44s] DEBUG: Seat seat0: Display server ready, starting session authentication
[+0.44s] DEBUG: Session pid=948: Started with service 'lightdm-greeter', username 'lightdm'
[+0.45s] DEBUG: Session pid=948: Authentication complete with return value 0: Success
[+0.45s] DEBUG: Seat seat0: Session authenticated, running command
[+0.45s] DEBUG: Session pid=948: Running command /usr/bin/lightdm-gtk-greeter
[+0.45s] DEBUG: Creating shared data directory /var/lib/lightdm-data/lightdm
[+0.45s] DEBUG: Session pid=948: Logging to /var/log/lightdm/seat0-greeter.log
[+0.47s] DEBUG: Activating VT 7
[+0.47s] DEBUG: Activating login1 session c7
[+0.47s] DEBUG: Seat seat0 changes active session to c7
[+0.47s] DEBUG: Session c7 is already active
[+0.61s] DEBUG: Greeter closed communication channel
[+0.61s] DEBUG: Session pid=948: Exited with return value 127
[+0.61s] DEBUG: Seat seat0: Session stopped
[+0.61s] DEBUG: Seat seat0: Stopping; failed to start a greeter
[+0.61s] DEBUG: Seat seat0: Stopping display server
[+0.61s] DEBUG: Sending signal 15 to process 939
[+0.63s] DEBUG: Seat seat0 changes active session to
[+0.77s] DEBUG: Process 939 exited with return value 0
[+0.77s] DEBUG: XServer 0: X server stopped
[+0.77s] DEBUG: Releasing VT 7
[+0.77s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+0.77s] DEBUG: Seat seat0: Display server stopped
[+0.77s] DEBUG: Seat seat0: Stopped
[+0.77s] DEBUG: Required seat has stopped
[+0.77s] DEBUG: Stopping display manager
[+0.77s] DEBUG: Display manager stopped
[+0.77s] DEBUG: Stopping daemon
[+0.77s] DEBUG: Exiting with return value 1
The problem reason may it be?.. (After pacman -Syu there is no error on this place)
seat0-greeter.log
/usr/bin/lightdm-gtk-greeter: symbol lookup error: /usr/lib/libtiff.so.6: undefined symbol: jpeg12_write_raw_data, version LIBJPEG_8.0
x-0.log
Current version of pixman: 0.43.4
	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: CENSORED 2024
And there is a file named wtmp in log file. I dont know what is this
I entered arch-chroot
did pacman -Syu libjpeg-turbo
now i have problems different
it is giving fatal library errors
I copied important files and did clean ISO install
