Im using cachyos on my old acer aspire e5, things are normal this morning but when i turned on the machine again it’s starting slowing/freezing while booting and just not on boot and also the system, idk what cause this, any idea?
Cody
October 24, 2025, 3:29pm
2
Mines been doing this after i open “openrgb” for some reason. They’ll want a bug report though.
cscs
October 24, 2025, 6:41pm
3
@Cody There are a bunch of disparate posts and open issues related to openrgb. ex:
@hdao133
Please perform the following and share the link it produces:
sudo cachyos-bugreport.sh
i cant even boot the system on now, it just keep spinning.
Cody
October 25, 2025, 8:36am
6
Yeah I gave a report on my post on this matter. I’m really happy to see that others are sharing this as well. It’s been a headache. Looks like it is infact the AMD driver side of things and how open RGB detects it.
cscs
October 25, 2025, 6:37pm
7
In the future you may consult;
Introduction
When we have problems gaining access to our systems it is difficult to gather information, let alone fix any problems. Here we will cover common causes and solutions to ‘cachyos wont boot’.
TTY
If your desktop does not load properly then you might still be able to use most, if not all, functionality by dropping to a non-graphical TTY.
By default your system will have multiple TTYs, with each corresponding to an Fx key. Your desktop is assigned to one as well - most often F1.
Yo…
As to the issue .. I dont see anything related to OpenRGB.
But I do see a lot of failures.
Oct 24 22:40:14 hdao systemd[1]: systemd-udevd.service: start operation timed out. Terminating.
Oct 24 22:40:20 hdao systemd[1]: systemd-resolved.service: start operation timed out. Terminating.
Oct 24 22:40:24 hdao systemd[1]: systemd-udevd.service: State 'stop-sigterm' timed out. Killing.
Oct 24 22:40:25 hdao systemd[1]: systemd-udevd.service: Main process exited, code=killed, status=9/KILL
Oct 24 22:40:25 hdao systemd[1]: systemd-udevd.service: Failed with result 'timeout'.
Oct 24 22:40:25 hdao systemd[1]: Failed to start Rule-based Manager for Device Events and Files.
Oct 24 22:40:26 hdao systemd[1]: systemd-resolved.service: Failed with result 'timeout'.
Oct 24 22:40:26 hdao systemd[1]: Failed to start Network Name Resolution.
Oct 24 22:40:40 hdao systemd[1]: systemd-udevd.service: start operation timed out. Terminating.
Oct 24 22:40:48 hdao systemd[1]: systemd-udevd.service: Failed with result 'timeout'.
Oct 24 22:40:48 hdao systemd[1]: Failed to start Rule-based Manager for Device Events and Files.
Oct 24 22:41:04 hdao systemd[1]: plymouth-start.service: start operation timed out. Terminating.
Oct 24 22:41:04 hdao systemd[1]: plymouth-start.service: Failed with result 'timeout'.
Oct 24 22:41:04 hdao systemd[1]: Failed to start Show Plymouth Boot Screen.
Oct 24 22:41:11 hdao systemd[1]: dev-disk-by\x2duuid-34131f52\x2d2a12\x2d4efb\x2da1a7\x2d280c6d4e2474.device: Job dev-disk-by\x2duuid-34131f52\x2d2a12\x2d4efb\x2da1a7\x2d280c6d4e2474.device/start timed out.
Oct 24 22:41:11 hdao systemd[1]: Timed out waiting for device /dev/disk/by-uuid/34131f52-2a12-4efb-a1a7-280c6d4e2474.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for /var/tmp.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for Local File Systems.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for /var/cache.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for /home.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for /srv.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for /root.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for /var/log.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for Flush Journal to Persistent Storage.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for Record System Boot/Shutdown in UTMP.
Oct 24 22:41:11 hdao systemd[1]: dev-disk-by\x2duuid-765C\x2d6754.device: Job dev-disk-by\x2duuid-765C\x2d6754.device/start timed out.
Oct 24 22:41:11 hdao systemd[1]: Timed out waiting for device /dev/disk/by-uuid/765C-6754.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for File System Check on /dev/disk/by-uuid/765C-6754.
Oct 24 22:41:11 hdao systemd[1]: Dependency failed for /boot.
So do you have some odd entries in /etc/fstab ?
And maybe also compare to lsblk -f or similar.
i dont know any about this, i just reinstall and anything work just fine now
hdao133
November 15, 2025, 2:31pm
9
bruh, just 20 days later its happen again.
here is the bug report:
