Multiple monitors stuck at low resolution with HDMI→DP adapters on NVIDIA
I recently installed CachyOS and I’m having issues with multiple monitors being detected at incorrect resolutions.
Hardware:
  • NVIDIA RTX 5060
  • KDE Plasma
  • Wayland (also tested X11)
  • Multiple HDMI monitors using HDMI-to-DisplayPort adapters connected to GPU
Problem:
  • One or more monitors lock to very low resolution (640x480 or similar)
  • KDE display settings do not show proper native resolutions
  • xrandr/modeline attempts fail
  • Sometimes monitor reports “-hsync”
  • Main monitor may work correctly while secondary monitors fail detection
Important detail:
These exact same monitors + adapters work correctly in Pop!_OS on the same hardware.
Things I already tested:
  • Rebooting with only one monitor attached
  • Different adapters
  • Wayland and X11
  • Power cycling monitors to reset EDID
  • Fresh CachyOS install
  • NVIDIA drivers included with CachyOS
  • Different ports on GPU
Question:
Has anyone seen EDID/handshake issues specifically with HDMI-to-DP adapters on CachyOS/KDE/NVIDIA?
I’m trying to determine whether this is:
  • KDE/Wayland related
  • NVIDIA driver related
  • Kernel related
  • Adapter compatibility issue
  • EDID parsing issue
Any ideas would be appreciated.
