Firstly, hello I am relatively new to CachyOS. Trying to move away from Windows. For the most part I have had minimal to no issues with CachyOS, except for my mouse and keyboard not behaving properly.
What I have noticed is that if I shutdown my PC my keyboard doesn’t turn off, the backlight stays on whereas on Windows it never had a problem. My mouse appears to turn off without problem, however the weird issue I have with my mouse is that if I reboot my PC the mouse goes off and then doesn’t come back on again (keyboard is fine however), I have to unplug my mouse and plug it back in again in order for it to come back.
I have checked (triple checked) all the USB power settings in my motherboard which is a ROG STRIX B650-A GAMING WIFI, I have updated to the latest possible BIOS etc, nothing appears to help. I know its not a CachyOS specific issue as I tried other distros e.g. Fedora, OpenSUSE, Ubuntu etc and they all exhibit the same problem.
My mouse is a Microsoft Intellimouse Pro and my keyboard is a Keychron Q1 QMK.
I have also tried different USB ports, same issue occurs on all USB ports I try. My other USB based devices have no issues switching off e.g. my USB hub, USB soundcard, bluetooth receiver etc. I am using a KVM Switch which my mouse and keyboard plug into, which I thought might be the culprit but as I said above I have tried all USB ports on my PC and it makes no difference. It appears to only be my mouse and keyboard impacted.
I have googled around and it appears other people in the past have had similar issues to me spanning back years across different distros etc, I have yet to find a solution that works… Please, can anyone help me?
I want to get away from Windows, and while this issue isn’t a big deal as such, its quite irritating to deal with.
Any help would be greatly appreciated, thank you.
p.s I notice that if I put my PC in standby or sleep, the mouse and keyboard turn off and on without issues. Only when shutdown/restart is when the issues occur.
