I can’t load Catchyos today.
I boot to the login screen, enter password.
As soon as I enter the password in the screen goes into standby mode.
I can press ctrl+alt+f3 and go to a tty3 terminal instead of using the GUI login.
It results in the same thing though. As soon as I enter the password in, monitor immediately goes to sleep.
This is with Wayland KDE Plasma.
Nvidia 4090.
Intel 12700F.
If I switch to X11 then it loads to the desktop as it should.
I’ve tried the following whilst in the X11 desktop environment.
I’m wondering if it’s something wrong with HDR or G-Sync. The problem is those options aren’t available in X11 so I can’t turn them off.
I’ve tried running a full system update in the terminal but no change.
Any help would be appreciated.
Should I try an older Kernel?
What happens when you switch back from the tty3 terminal to the graphical console?
I had the problem that the switch from the login manager (sddm) to the plasma graphical console did not work correctly and switching manually with ctrl-alt-f-keys worked, so just try switching back.
Yeah it’s definitely the HDR setting.
Created a new user and Wayland booted fine.
edit:
I edited kwinoutputconfig.json and switch HDR and wide color gamut to ‘false’.
I still get the error when I log out and in again on Wayland.
I rebooted and check the file and it’s back to ‘true’ for those settings.
