Module binder_linux not found
Trying to get WayDroid running and it doesn’t start and I believe it’s because binder isn’t installed. When I run “sudo modprobe -a binder_linux” I get “modprobe: WARNING: Module binder_linux not found in directory /lib/modules/6.12.13-1-cachyos-hardened-lto”. Doesn’t this come preinstalled in the kernel? How do I install this?
It’s not built in that kernel. Use a different one.
Which one has it? There’s so many choices and no indication which one would have it.
All the kernels except hardened kernel has it.
It’s in the Kconfig.
