Microsoft Edge on Steam not opening
Deal All,
I use Cachy os on a Legion go. The experience is great. Ià ve added MS Edge on desktop mode. If I open it from Kde it works.
Then I ve added it to steam in order to use a Xbox Gamepass Cloud launcher. If I try to open Edge from steam nothing happen.
Can you help me?
L.
It was my fault. I installed Edge using Pacman, and I had to use Flatpak.
