Mayflash Wii Sensor Bar Not Working in Dolphin
Hello,
My Mayflash is detected by CachyOS and I can sync my Wiimote. I set the correct parameters in Dolphin as I would in Windows 11. It works fine on Windows. I get this error message when I try to launch a game with the correct Dolphin parameters:
Remote at “/dev/hidraw3”. Do you have permission to access the device?43:15:688 InputCommon/ControllerInterface/evdev/evdev.cpp:392 N[CI]: evdev hotplug thread stopped43:15:732 Core/HW/WiimoteReal/IOhidapi.cpp:21 E[Wiimote]: Could not connect to Wii Remote at “/dev/hidraw0”. Do you have permission to access the device?43:15:732 Core/HW/WiimoteReal/IOhidapi.cpp:21 E[Wiimote]: Could not connect to Wii Remote at “/dev/hidraw1”. Do you have permission to access the device?43:15:732 Core/HW/WiimoteReal/IOhidapi.cpp:21 E[Wiimote]: Could not connect to Wii Remote at “/dev/hidraw2”. Do you have permission to access the device?43:15:732 Core/HW/WiimoteReal/IOhidapi.cpp:21 E[Wiimote]: Could not connect to Wii Remote at “/dev/hidraw3”. Do you have permission to access the device?43:16:136 Core/HW/WiimoteReal/WiimoteReal.cpp:780 N[Wiimote]: Wiimote scanning thread has stopped. 43.6:136 Core/HW/WiimoteReal/WiimoteReal.cpp:909 N[Wiimote]: WiimoteReal::Shutdown
Any help you can give would be great. At first I thought it was a group issue and added myself to the input and games group. Should I post to the Dolphin forum or is it a CachyOS issue? Thanks a lot for your help.
Did you ever happen to find a solution to this?
I got it partially working by adding a udev rules file here: dolphin/Data/51-usb-device.rules at master · dolphin-emu/dolphin · GitHub
Buttons work, but motion tracking does not (wiimote/dolphin bar confirmed working just fine when hooked up to a steam deck).
