is there a guide to install on macbook air Model A1466 . or is it to old to install Cachyos .. try to install it but no luck ![]()
Good day to all
Good day to all
The installation shouldn’t be a problem since there’s no TL2 chip. However, some users have reported Wi-Fi issues.
What exactly caused the installation to fail?
cannot get past login screen .. on fresh install no key working ![]()
im getting Zorin 18.1 working .. only webcam is the problem ..
Attention! The current custom kernels from CachyOS do not work. You must use a regular Linux kernel.
