Cachy has been a total pleasure up until recently. It ran my game like butter. Since updating to version seven however, there is a significant performance drop.
As a new user, I’d like some input/direction as to how to approach troubleshooting this. Where do i even begin lol. I could try rolling the kernel back as has been suggested online. I’d just like to understand what changed! also, is there a way to navigate to very old snapshots on limine? (beyond the selection menu at boot)
*forgive my ignorance, just trying to learn how to help myself better here.
Not least of which because we are rolling-release distro.
But there was linux kernel 7.0 released, or rather moved from ‘mainline’ into ‘stable’, somewhat recently. With 7.1-rc5 being the new current ‘mainline’.
If you want to continue using an older kernel you can install one of the LTS ones - the most recent of which correlates to 6.18.X.
Apologies for ignorance of vernacular. yes, the Kernel release is what i was refrencing. The LTS version has the same dropped performance in game.
edit: in doing a sudo -Syu, there were a couple times i saw warnings, but proceeded anyway (will not be repeating that behavoir) could that have led to this change?
Second Edit: I’d like to try and repair, but if a fresh OS install could clean up any mistakes, i’ll happily settle for that
I do note you have missing/pending BIOS updates.
Maybe less likely to be related here but probably something to be done regardless.
Maybe after we have finished the current query.
I notice here you have seemingly set the CPU and PPD to ‘powersave’ - is this intentional?
It might be set in the power widget slider.
Well, Powerprofile set to Performance, it does seem there is more cpu ulilization, but there is stil a performance drop…
edit: No changes to installed addons, graphics settings, hardware etc. Just an -Syu which resulted in about 15 fps loss and occasional stuttering. Wondering if this isnt somethign to do with steam…
