I just had weird lock up in Genshin Impact (judge me all you want xD)
I decided to Alt-Tab out and do a reboot.
After that the wireless feature of the G502 stopped working again. I connected it to cable and it works fine.
I gave it some time to charge the battery in case that’s the issue but no, just doesn’t work.
Is there any kind of debugging I can do to help solve this issue?
I’m fairly sure my fix of running the Windows ISO from a USB stick will work just as well as the last time. (For anybody else having the same issue and looking for a quick fix - It worked for 2-3 weeks after that and no idea what the actual problem is.)
I’m far away from investing into hardware to eavesdrop on the wireless talk but surely there’s some way to provide detailed information on working and non working configurations, like lsusb on steroids.
I’d appreciate any pointers and ig this bug goes upstream to libinput?
