Linux kernel 6.9 and sleep not working correctly
Anyone else having any issues with sleep with the new kernel 6.9?
The problem I am experiencing is that the computer seems to not sleep at all. It stays hot, and the battery is almost empty the next morning.
CPU is Intel core 7H
I dont think there is anything interesting in dmesg, but here it is anyways:
[ 3445.288445] PM: suspend entry (s2idle)
[ 3445.294663] Filesystems sync: 0.006 seconds
[ 3445.304702] Freezing user space processes
[ 3445.307236] Freezing user space processes completed (elapsed 0.002 seconds)
[ 3445.307247] OOM killer disabled.
[ 3445.307249] Freezing remaining freezable tasks
[ 3445.308484] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ 3445.308490] printk: Suspending console(s) (use no_console_suspend to debug)
[ 3445.359995] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Asserting Reset
[ 3445.366108] intel-hid INTC1077:00: failed to get button capability
[ 3445.505658] ACPI: EC: interrupt blocked
[ 3932.863816] ACPI: EC: interrupt unblocked
[ 3932.921401] pci 0000:00:08.0: Setting to D3hot
[ 3932.933459] pci 0000:00:0b.0: Setting to D3hot
[ 3932.954346] intel-hid INTC1077:00: failed to get button capability
[ 3932.969314] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 3932.971222] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/mtl_guc_70.bin version 70.20.0
[ 3932.983540] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
[ 3932.983543] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
[ 3932.983746] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
[ 3932.984225] i915 0000:00:02.0: [drm] GT1: GuC firmware i915/mtl_guc_70.bin version 70.20.0
[ 3932.984227] i915 0000:00:02.0: [drm] GT1: HuC firmware i915/mtl_huc_gsc.bin version 8.5.4
[ 3932.998324] i915 0000:00:02.0: [drm] GT1: GUC: submission enabled
[ 3932.998325] i915 0000:00:02.0: [drm] GT1: GUC: SLPC enabled
[ 3932.998446] i915 0000:00:02.0: [drm] GT1: GUC: RC enabled
[ 3933.022629] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: Firmware version: 3
[ 3933.022634] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431a63.wmfw: Fri 31 Mar 2023 10:42:49 W. Europe Daylight Time
[ 3933.084570] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: Firmware: 400a4 vendor: 0x2 v0.65.0, 2 algorithms
[ 3933.085663] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431a63-spkid1-l0.bin: v0.65.0
[ 3933.085668] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: spk-prot: C:\Users\tyang\Desktop\Product Setting\SmartAMP\ASUS\ASUS_Zenbook\2023Projects\UX3405MA\Tuning_release\06082023\UX3405UM_19p5dB_Mock_VECO_Lch_finish_ID_6p83_US_Xmax0p65.bin
[ 3933.113297] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: Firmware version: 3
[ 3933.113299] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431a63.wmfw: Fri 31 Mar 2023 10:42:49 W. Europe Daylight Time
[ 3933.124245] iwlwifi 0000:00:14.3: Not valid error log pointer 0x0027B0C0 for RT uCode
[ 3933.124270] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 3933.124279] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 3933.124285] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x80
[ 3933.124293] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 3933.125146] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 3933.174534] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: Firmware: 400a4 vendor: 0x2 v0.65.0, 2 algorithms
[ 3933.175178] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431a63-spkid1-r0.bin: v0.65.0
[ 3933.175181] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: spk-prot: C:\Users\tyang\Desktop\Product Setting\SmartAMP\ASUS\ASUS_Zenbook\2023Projects\UX3405MA\Tuning_release\06082023\UX3405UM_19p5dB_Mock_VECO_Rch_finish_ID_6p83_UX_Xmax0p65.bin
[ 3933.273506] mei_gsc_proxy 0000:00:16.0-0f73db04-97ab-4125-b893-e904ad0d5464: bound 0000:00:02.0 (ops i915_gsc_proxy_component_ops [i915])
[ 3933.274148] OOM killer enabled.
[ 3933.274151] Restarting tasks … done.
[ 3933.278128] random: crng reseeded on system resumption
[ 3933.352687] PM: suspend exit
[ 3933.411501] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 3933.566433] iwlwifi 0000:00:14.3: Not valid error log pointer 0x0027B0C0 for RT uCode
[ 3933.566467] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 3933.566478] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 3933.566485] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x80
[ 3933.566493] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 3933.567327] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 3937.653724] wlan0: authenticate with 44:f0:34:ae:63:38 (local address=b0:3c:dc:7f:20:fb)
[ 3937.654324] wlan0: send auth to 44:f0:34:ae:63:38 (try 1/3)
[ 3937.683491] wlan0: authenticated
[ 3937.684597] wlan0: associate with 44:f0:34:ae:63:38 (try 1/3)
[ 3937.685754] wlan0: RX AssocResp from 44:f0:34:ae:63:38 (capab=0x11 status=0 aid=7)
[ 3937.687808] wlan0: associated
[ 3937.704192] Ignoring NSS change in VHT Operating Mode Notification from 44:f0:34:ae:63:38 with invalid nss 3
[ 3937.704198] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 44:f0:34:ae:63:38
[ 3996.996211] [UFW BLOCK] IN=wlan0 OUT= MAC=b0:3c:dc:7f:20:fb:44:f0:34:ae:63:37:08:00 SRC=10.0.0.138 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 4121.976061] [UFW BLOCK] IN=wlan0 OUT= MAC=b0:3c:dc:7f:20:fb:44:f0:34:ae:63:37:08:00 SRC=10.0.0.138 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 4247.265201] [UFW BLOCK] IN=wlan0 OUT= MAC=b0:3c:dc:7f:20:fb:44:f0:34:ae:63:37:08:00 SRC=10.0.0.138 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
Forgot to mention, this happens with the linux-cachyos and linux-cachyos-lto kernels.
Dont know if there is any more info that could be interesting. Nothing particular in journal either.
You can try to downgrade the kernel from the archive: CachyOS - Repo
Yes, it works fine with the 6.8 kernel. Tested now.
Edit: Same issue with the original Arch kernel, so I suppose this is an upstream bug. However, I have not managed to find any reported bugs about this.
I ran into s2idle waking up instantly as well on cachyos kernel 6.10
Downgrading to 6.8 fixed it for me as well
This is fixed for me in 6.10
@Holden92 hi, thanks. Recently fixed? Exactly which 6.10 (cachyOs) kernel fixed it for you? I was on 6.10 when I ran into the suspend issue.
I will figure out exactly which version…
@Holden92 I figured out exactly on which 6.10 kernel I ran into OP. It was linux-cachyos 6.10.1-3 stable (got it from checking the checkboxes in cachyos-kernel-manager).
So then I wonder which 6.10 kernel exactly solved it for you. As there are some…
Started to work fine in the first 6.10 cachyos default kernel. And still works fine for the newest release too. You might have a different bug if its not working for you.
