Hello,
I purchased a USB/USB-C network adapter, which contains a Realtek Semiconductor USB 10/100/1G/2.5G LAN chip. The system recognized the card without any issues, the internet is working, but the maximum download speed it reaches is 1400Mbps (connected via USB-C). I get slightly better speeds over Wi-Fi.
Does anyone have any suggestions on how I can make the card support the maximum speed of my connection, which is 2Gbps?
Kernel: 6.12.4-s
USB-C: 3.2 Gen 1 5Gbps Data Transfer
I tested it on LiveCD Linux Mint, and the download speed is at a maximum of 2100Mbps. On CashyOS, both with wired and wireless connections, the download speed is a maximum of 1400Mbps. Is it possible that there is a limit set somewhere in the system?
speedtest-cli
Retrieving speedtest.net configuration...
Testing from Orange Polska (83.30.131.70)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Syrion Sp. z o.o. (Zory) [89.02 km]: 6.259 ms
Testing download speed................................................................................
Download: 1682.97 Mbit/s
Testing upload speed......................................................................................................
Upload: 578.57 Mbit/s
Yes, now is ok. The problem occurs only on browser-based speed tests. But overall, everything is fine now. Thank you for your help.
❯ speedtest-cli
Hosted by Syrion Sp. z o.o. (Zory) [89.02 km]: 5.232 ms
Download: 2016.38 Mbit/s
Upload: 534.92 Mbit/s
I have one more question: when I boot the system, I now have 3 kernel versions to choose from. How can I clean this up so that I only have the options CashyOS + CashyOS (fall back)?
@kozacki These are the various sysctls we set related to networking. Do you mind helping us bisect which of these sysctls are problematic so we can drop them? Firstly, reinstall the cachyos-settings package and reboot
The changes you make with the command aren’t persisted on reboot, I would think that restarting the connection should be sufficient. If not, you would need to change the settings in /usr/lib/sysctl.d/99-cachyos-settings.conf and reboot after each change.
It’s hard to say because one speed test shows 1400, another 1000, and the terminal one, which used to be the fastest, now shows 100-500. I understand there can be differences between them, but such big ones?
