Legion Go - Audo Sync issues when docked
Currently having some issues when attempting to play docked game mode on my Lenovo Legion Go.
On desktop mode, the audio is perfectly synced with my monitor or tv. Although, once I enter gamemode the audio has a lag delay and does not sync with any games or menu options
Bug report
It looks like you are experiencing some xruns.
Try adding this to ~.config/pipewire/pipewire.conf.d/bump-quant.conf
context.properties = {
    default.clock.min-quantum = 256
I’ll try it.
But do you mind explaining what xruns are?
it’s a buffer under-or-overrun, X stands for under or over. It’s a sign that your system did not process some buffers in time, so some data is missed.
I looked and i have no pipewire folder
You need to create it, so it picks it to addition the system wide pipewire config
