I am unable to get output on my HDMI with a fresh install of CachyOS. The behavior persists whether I am using X11 or Wayland. KDE appears to detect the HDMI connection and asks how I want to display the new monitor, but it does not appear to matter what I select, it never outputs. I am using all the default options and have not altered or added any kernel parameters or config files.
I have confirmed that HDMI Out works on a fresh install of OpenSUSE Tumbleweed with the Nvidia drivers installed both on X11 and Wayland, so I know the BIOS is configured where the output is possible. A cursory seach for Arch documentation did not yield any advice that worked on a previous install.
Systems specs
System:
Host: CompyL5C Kernel: 6.9.6-2-cachyos arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.1.0 Distro: CachyOS
Machine:
Type: Laptop System: LENOVO product: 82RF v: Legion 5 Pro 16IAH7H
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: <superuser required> UEFI: LENOVO v: J2CN57WW date: 01/08/2024
Battery:
ID-1: BAT0 charge: 73.3 Wh (94.9%) condition: 77.2/80.0 Wh (96.4%)
CPU:
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
type: MST AMCP cache: L2: 11.5 MiB
Speed (MHz): avg: 1406 min/max: 400/4600:4700:3500 cores: 1: 393 2: 400
3: 400 4: 400 5: 4566 6: 400 7: 2132 8: 400 9: 1187 10: 4251 11: 400 12: 400
13: 2641 14: 1764 15: 400 16: 3292 17: 400 18: 3500 19: 400 20: 400
Graphics:
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] driver: nvidia
v: 555.52.04
Device-3: Bison Integrated Camera driver: uvcvideo type: USB
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: modesetting dri: iris
gpu: i915,nvidia resolution: 1707x1067
API: EGL v: 1.5 drivers: iris,nvidia,swrast
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.2-arch1.2
renderer: Mesa Intel Graphics (ADL GT2)
API: Vulkan v: 1.3.285 drivers: nvidia,intel surfaces: xcb,xlib,wayland
Audio:
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.9.6-2-cachyos status: kernel-api
Server-1: PipeWire v: 1.0.7 status: active
Network:
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi
IF: wlan0 state: up mac: a0:29:42:71:dc:1b
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp52s0 state: down mac: e8:80:88:1e:ef:21
Bluetooth:
Device-1: Intel AX211 Bluetooth driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: A0:29:42:71:DC:1F bt-v: 5.3
Drives:
Local Storage: total: 1.39 TiB used: 20.55 GiB (1.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB
ID-2: /dev/nvme1n1 vendor: Samsung model: MZVL21T0HCLR-00BL2
Partition:
ID-1: / size: 463.76 GiB used: 19.99 GiB (4.3%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot size: 2 GiB used: 575.9 MiB (28.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 463.76 GiB used: 19.99 GiB (4.3%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 463.76 GiB used: 19.99 GiB (4.3%) fs: btrfs
dev: /dev/nvme0n1p2
ID-5: /var/tmp size: 463.76 GiB used: 19.99 GiB (4.3%) fs: btrfs
dev: /dev/nvme0n1p2
Swap:
ID-1: swap-1 type: zram size: 15.35 GiB used: 768 KiB (0.0%) dev: /dev/zram0
Sensors:
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Memory: total: 16 GiB note: est. available: 15.35 GiB used: 4.21 GiB (27.4%)
Processes: 421 Uptime: 7m Shell: fish inxi: 3.3.35
