After an update a few weeks ago, my keyboard’s rgb has been resetting to white after I login. It fixes itself if I unplug it and plug it back in, but that is annoying to have to do every time I login. Does anyone know what could be causing this or how to fix it? For reference, my keyboard is a Keychron v6 (QMK compatible if it helps). Thanks!
There was an OpenRGB update about a couple of weeks ago, I think. Are you using that perhaps?
Nope, my keyboard isn’t even recognized by OpenRGB
Looks like it is already a known bug for KDE Plasma and will be fixed with the release of 6.7.3.
