Keyboard and Touch Keyboard using Hiragana
Hi, I want to use both the regular and the touch keyboard with Hiragana on my Lenovo ThinkPad X13 Yoga Gen 2. How do I do that?
It all works out of the box on Windoof
thx
Does no one have a solution?
Yes, it’s a little complicated:
  1. You need to install:
    fcitx5
    fcitx5-mozc
    fcitx5-configtool
    plasma-keyboard
  2. Go to System-Settings → Keyboard → Virtual Keyboard → Chose Fcitx5 Wayland Launcher → Apply
  3. System-Settings → Input Method → Add Input Method → Mozc
  4. Now you should see a kayboard icon on the taskbar → left klick to switch to a different layout if needed.
  5. I don’t have a touch screen but plasma-keyboard, maybe works. See Video below. After install go to System-Settings→ Keyboard → On-Screen Keyboard and try it with Japanese. It should POP Up if you touch a text editor window.
Touch and keyboard work fine on their own with Hiragana, but I always have to manually switch between touch and Japanese keyboard layouts in Virtual Keyboard…
It’s a shame that Linux doesn’t allow this, unlike Windows where you can have both at the same time…
You can always show the on-screen keyboard with
sudo nano /etc/environment
and add: KWIN_IM_SHOW_ALWAYS=1
restart after
