ndowens
December 17, 2024, 7:00pm
1
I changed to a nvme drive, so I reinstalled cachyos. I used the defaults of the install on partition section and FS types, except changed / to be btrfs. I noticed after the initial install when I updated, the kernel image and initrd disappeared from /boot. Also tried installing linux-cachyos-bore kernel and it does not get installed to /boot nor does a mkinitcpio preset gets installed. What would cause this issue? My ESP isn’t full btw
Edit: Update, linux-zen when I tested installing it, it showed up in my ESP partition
naim
December 18, 2024, 8:50am
2
Which boot manager are you using? Also show me your partition table.
ndowens
December 18, 2024, 11:20pm
4
Was using systemd-boot but went back to grub as I’m use to it.
Inxi: termbin.com/ek916
Parted: termbin.com/hzw3
Also I figured out linux-zen would install in /boot but not linux-cachyos{-bore}
naim
December 19, 2024, 7:45am
5
Can you give me a long listing of /boot? ls -la /boot
and ls -la /boot/efi
ndowens
December 19, 2024, 9:52am
6
ls -la /boot
drwxr-xr-x - root 31 Dec 1969 .
drwxr-xr-x - root 16 Dec 04:22 …
drwxr-xr-x - root 9 Dec 21:07 2fa08ec140964eda85c061c49e12c691
drwxr-xr-x - root 16 Dec 04:05 EFI
drwxr-xr-x - root 18 Dec 04:13 grub
drwxr-xr-x - root 13 Dec 03:01 loader
.rwxr-xr-x 139M root 18 Dec 00:36 initramfs-linux-cachyos.img
.rwxr-xr-x 14M root 16 Dec 04:19 vmlinuz-linux-cachyos
The images above for linux-cachyos is the ones I copied from the /lib/modules/linux-cachyos… dir
ls -la /boot/efi
drwxr-xr-x - root 16 Dec 04:05 .
drwxr-xr-x - root 31 Dec 1969 …
drwxr-xr-x - root 16 Dec 04:05 arch
drwxr-xr-x - root 10 Dec 15:06 BOOT
drwxr-xr-x - root 9 Dec 21:07 Linux
drwxr-xr-x - root 10 Dec 15:06 systemd
naim
December 19, 2024, 5:22pm
7
I think for one thing, your partition table is wrong for GRUB. The partition where it keeps the kernel images must be separate from the EFI partition, which is your current boot. Whether it’s the reason for the underlying issue is unclear. Can you give me the install log of the bore kernel?
sudo pacman -S linux-cachyos-bore <and-others>
ndowens
December 19, 2024, 8:54pm
9
Origionally I was using systemd-boot and the partition table setup was done by the installer.
linux-cachyos-bore-6.12.5-1-x86_64_v3 143.1 MiB 6.06 MiB/s 00:24 [----------------------------------------] 100%
(2/2) checking keys in keyring [----------------------------------------] 100%
(2/2) checking package integrity [----------------------------------------] 100%
(2/2) loading package files [----------------------------------------] 100%
(2/2) checking for file conflicts [----------------------------------------] 100%
:: Processing package changes…
(1/2) installing linux-cachyos-bore [----------------------------------------] 100%
Optional dependencies for linux-cachyos-bore
wireless-regdb: to set the correct wireless channels of your country [installed]
linux-firmware: firmware images needed for some devices [installed]
modprobed-db: Keeps track of EVERY kernel module that has ever been probed - useful for those of us who make
localmodconfig
scx-scheds: to use sched-ext schedulers [installed]
(2/2) installing linux-zen [----------------------------------------] 100%
Optional dependencies for linux-zen
:: Running post-transaction hooks…
(1/5) Arming ConditionNeedsUpdate…
(2/5) Updating module dependencies…
(3/5) Updating initramfs…
:: Building initramfs for linux-cachyos-bore (6.12.5-1-cachyos-bore)
dracut[I]: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /boot/initramfs-linux-cachyos-bore.img 6.12.5-1-cachyos-bore
dracut[I]: 95nfs: Could not find any command of ‘rpcbind portmap’!
dracut[I]: *** Including module: systemd ***
dracut[I]: *** Including module: systemd-ask-password ***
dracut[I]: *** Including module: systemd-initrd ***
dracut[I]: *** Including module: systemd-journald ***
dracut[I]: *** Including module: systemd-modules-load ***
dracut[I]: *** Including module: systemd-sysctl ***
dracut[I]: *** Including module: systemd-sysusers ***
dracut[I]: *** Including module: systemd-tmpfiles ***
dracut[I]: *** Including module: systemd-udevd ***
dracut[I]: *** Including module: i18n ***
dracut[I]: *** Including module: drm ***
dracut[I]: *** Including module: plymouth ***
dracut[I]: *** Including module: btrfs ***
dracut[I]: *** Including module: kernel-modules ***
dracut[I]: *** Including module: kernel-modules-extra ***
dracut[I]: *** Including module: pcmcia ***
dracut[I]: *** Including module: systemd-boot-snapshots ***
dracut[I]: *** Including module: btrfs-snapshot-overlay ***
dracut[I]: *** Including module: hwdb ***
dracut[I]: *** Including module: rootfs-block ***
dracut[I]: *** Including module: terminfo ***
dracut[I]: *** Including module: udev-rules ***
dracut[I]: *** Including module: dracut-systemd ***
dracut[I]: *** Including module: usrmount ***
dracut[I]: *** Including module: base ***
dracut[I]: *** Including module: fs-lib ***
dracut[I]: *** Including module: shutdown ***
dracut[I]: *** Including modules done ***
dracut-install: Failed to find module ‘nvidia_drm’
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.hYb2Bt/initramfs --kerneldir /lib/modules/6.12.5-1-cachyos-bore/ -m nvidia_drm
dracut[I]: *** Installing kernel module dependencies ***
dracut[I]: *** Installing kernel module dependencies done ***
dracut[I]: *** Resolving executable dependencies ***
dracut[I]: *** Resolving executable dependencies done ***
dracut[I]: *** Hardlinking files ***
dracut[I]: *** Hardlinking files done ***
dracut[I]: *** Generating early-microcode cpio image ***
dracut[I]: *** Store current command line parameters ***
dracut[I]: *** Stripping files ***
dracut[I]: *** Stripping files done ***
dracut[I]: *** Creating image file ‘/boot/initramfs-linux-cachyos-bore.img’ ***
dracut[I]: Using auto-determined compression method ‘zstd’
dracut[I]: *** Creating initramfs image file ‘/boot/initramfs-linux-cachyos-bore.img’ done ***
:: Building initramfs for linux-zen (6.12.5-zen1-1-zen)
dracut[I]: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /boot/initramfs-linux-zen.img 6.12.5-zen1-1-zen
dracut[E]: FAILED: /usr/lib/dracut/dracut-install -D /var/tmp/dracut.3k0iqg/initramfs --kerneldir /lib/modules/6.12.5-zen1-1-zen/ -m nvidia_drm
dracut[I]: *** Creating image file ‘/boot/initramfs-linux-zen.img’ ***
dracut[I]: *** Creating initramfs image file ‘/boot/initramfs-linux-zen.img’ done ***
(4/5) Updating linux initcpios…
call to execv failed (No such file or directory)
error: command failed to execute correctly
(5/5) Updating systemd-boot entries
ndowens
December 19, 2024, 8:57pm
10
Switched to dracut, but here is fstab https://termbin.com/qfi0
Edit: ATM it seems to be working fine now, the only change I’ve made was to switch to dracut
ndowens
December 20, 2024, 7:12am
12
Removed the remount part, and changed the add_modules in dracut for nvidia
