So every time I open discord kdewallet wants a password. How do I stop this from opening every time or just simply get rid of kdewallet cause Ill never use it
are you using auto login when booting CachyOs
kdewallet stores keyring and secrets for apps that use it so you definitely will (and are) use(ing) it. If it prompts for password, that means that kdewallet’s passkey isn’t the same as your login password. Setting it to be the same as your login password or leaving it blank will workaround this.
https://wiki.archlinux.org/title/KDE_Wallet
Discord AFAIK is an Electron application, so more or less a Webpage running in a pretty crappy Chrome/Chromium. Electron applications are a constant pain in the ass and should be avoided if possible. Just open Discord in a browser instead if possible.
I am using auto log in
I never set anything up with kdewallet. When the prompt pops up for the password i just click cancel and go abouts my day. Its just an annoyance of it popping up every time i open discord
try disabling auto login and then try and then reboot or logout and login, see if you face the same when opening discord
