Running CachyOS KDE Plasma fully updated on a newish mini PC (Beelink SER8).
Something keeps happening with the iGPU which I don’t know how to fix:
For no reason at all, the AMD Radeon 780M iGPU switches to software mode?
The only thing I can do is to restore a system backup using Timeshift.
System info is below.
Please help, thanks!
SS
inxi -F
System:
Host: ser8-mini-pc Kernel: 6.17.9-arch1-1 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.5.3 Distro: CachyOS
Machine:
Type: Mini-pc Mobo: AZW model: SER8 v: V10 serial: <superuser required>
Firmware: UEFI vendor: American Megatrends LLC.
v: HPT.8xxx.SER8.V029.P8C0M0C15.13.Link date: 02/21/2025
CPU:
Info: 8-core model: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics bits: 64
type: MT MCP cache: L2: 8 MiB
Speed (MHz): avg: 1101 min/max: 419/5138 cores: 1: 1101 2: 1101 3: 1101
4: 1101 5: 1101 6: 1101 7: 1101 8: 1101 9: 1101 10: 1101 11: 1101 12: 1101
13: 1101 14: 1101 15: 1101 16: 1101
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] HawkPoint1 driver: amdgpu
v: kernel
Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting
dri: radeonsi gpu: amdgpu resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.7-cachyos1.2
renderer: AMD Radeon 780M Graphics (radeonsi phoenix LLVM 21.1.5 DRM 3.64
6.17.9-arch1-1)
API: Vulkan v: 1.4.328 drivers: radv surfaces: N/A
de: kscreen-console,kscreen-doctor wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Audio:
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
driver: snd_pci_ps
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
API: ALSA v: k6.17.9-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active
Network:
Device-1: Realtek RTL8125 2.5GbE driver: r8169
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: 70:70:fc:07:02:47
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlan0 state: down mac: 86:90:2c:38:16:b9
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: 70:D8:C2:52:10:D3 bt-v: 5.2
Drives:
Local Storage: total: 11.82 TiB used: 265.28 GiB (2.2%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P3PSSD8 size: 931.51 GiB
ID-2: /dev/sda vendor: Seagate model: ST12000VN0008-2YS101 size: 10.91 TiB
type: USB
Partition:
ID-1: / size: 913.83 GiB used: 264.97 GiB (29.0%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 2 GiB used: 318 MiB (15.6%) fs: vfat dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: zram size: 23.25 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors:
System Temperatures: cpu: 38.9 C mobo: 37.0 C gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): N/A
Info:
Memory: total: 24 GiB available: 23.25 GiB used: 8.16 GiB (35.1%)
Processes: 476 Uptime: 1h 3m Shell: fish inxi: 3.3.40
