Hi. After updating to KDE 6.1, sddm doesn’t fully display my language on the login screen. The date and time formats are correct. However, the fields shown in the picture are not in my language. I’m referring to Polish. I’ve seen this issue reported on other distros as well. I searched online but couldn’t find anyone reporting it. Is this a bug or an issue with a misconfigured distribution?
sddm is actually independant from KDE. Ill look up, if there is any configuration for to set the correct language.
Okay, I’m waiting for further response
Try to change the language in this file sudo nano /etc/sddm.conf
The file is empty
You want this in polish language?
Add to that file then
[General]
Language=pl_PL
I did it, but it didn’t work
@ptr1337 @legendboyAni
It turns out that I am not the only one with this problem. KDE Forum:
This also might help you:
I tried it and it doesn’t work
I’ve this problem with KDE Arch Linux on my Laptop and CachyOS on my “Main-System” aswell and waiting for a offical fix. I guess that 6.1 is still kind of “early access”
It doesn’t bother me that much.
