Is there a status.alhp.dev like site for CachyOS?
I found that VLC is no longer provided in the znver4 repository, so I want to know is there a site like status.alhp.dev where I can check the build status for cachy packages.
I also want to know why VLC is removed from znver4 repository. Is it a temporary build fail or a long time blacklist? Is there any specific reason?
EDIT: I found that VLC was just being built for the znver4 repository as the package reappeared. Anyway the question for status site is still valid.
Yes, we have one but its currently behind a login, its basically a full dashbaord to add/rebuild packages and its status.
We are working on providing a public variant. The failed packages logs are publically available tough, see for exmaple:
https://builder-api.cachyos.org/api/v1/logs/x86-64-v4/libarchive.log
You can just replace with a package name the log, to see if there is a failed package.
