Intermittent NVMe Issue with KLEVV CRAS C910 4TB (VF101C59)
Been having this issue for a while where this drive will only work under Linux/Arch/CachyOS (current) in specific conditions.
The condition: Cold Boot to Win11 from either Grub or BIOS, Drive is Present, then Reboot into CachyOS, Drive usually shows up.
Sometimes the drive won’t show so I must then go back to windows11 from a COLD boot and attempt to get it to show under Linux again.
I have been collecting loads of data on this issue, at present the drive is mounted. But before I continue, please understand this issue does not appear to be related to nvme_core.default_ps_max_latency_us=0 as per arch recommended fix. This does nothing.
I need help in isolating how to push this device bug upstream to get a patch made for Linux. Kind of sick of running into this issue and having no SOLID fix!
The motherboard in used is ASUS PRIME B840M-A WIFI with latest BIOS
CACHYOS SYSTEM INF
          .-------------------------:                    gerarderloper@underverse-host
         :++===++==================-       :++-           OS: CachyOS x86_64
        :*++====+++++=============-        .==:           Kernel: Linux 6.13.6-2-cachyos
       -*+++=====+***++==========:                        Uptime: 20 mins
      =*++++========------------:                         Packages: 1415 (pacman), 51 (flatpak)
     =*+++++=====-                     ...                Shell: fish 4.0.0
   .+*+++++=-===:                    .=+++=:              Display (KAMN26F7SA): 2560x1080 @ 75 Hz (as 2048x864) in 26" [External]
  :++++=====-==:                     -*****+              Display (LG TV SSCR2): 3840x2160 @ 144 Hz (as 2560x1440) in 72" [External, HDR] *
 :++========-=.                      .=+**+.              DE: KDE Plasma 6.3.3
.+==========-.                          .                 WM: KWin (Wayland)
 :+++++++====-                                .--==-.     WM Theme: Breeze
  :++==========.                             :+++++++:    Theme: Breeze (Dark) [Qt], Breeze-Dark [GTK2], Breeze [GTK3]
   .-===========.                            =*****+*+    Icons: breeze-dark [Qt], breeze-dark [GTK2/3/4]
    .-===========:                           .+*****+:    Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
      -=======++++:::::::::::::::::::::::::-:  .---:      Cursor: volantes (32px)
       :======++++====+++******************=.             Terminal: konsole 24.12.3
        :=====+++==========++++++++++++++*-               CPU: AMD Ryzen 7 7800X3D (16) @ 5.05 GHz
         .====++==============++++++++++*-                GPU: NVIDIA GeForce RTX 4090 [Discrete]
          .===+==================+++++++:                 Memory: 7.23 GiB / 62.45 GiB (12%)
           .-=======================+++:                  Swap: 0 B / 62.45 GiB (0%)
             ..........................                   Disk (/): 75.92 GiB / 1.79 TiB (4%) - ext4
                                                          Disk (/mnt/GamesNVMe): 593.77 GiB / 3.64 TiB (16%) - ntfs3
                                                          Disk (/mnt/GamesNVMe2): 95.23 MiB / 1.86 TiB (0%) - btrfs
                                                          Disk (/mnt/StorageNVMe): 1.34 TiB / 1.82 TiB (74%) - btrfs
                                                          Local IP (wlan0): 192.168.1.20/24
                                                          Locale: en_AU.UTF-8
Incoming data dump:
PCI ID:
09:00.0 Non-Volatile memory controller: Realtek Semiconductor Co., Ltd. RTS5772DL NVMe SSD Controller (DRAM-less) (rev 01) (prog-if 02 [NVM Express])
	Subsystem: Realtek Semiconductor Co., Ltd. RTS5772DL NVMe SSD Controller (DRAM-less)
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 34
	IOMMU group: 16
	Region 0: Memory at f6c00000 (64-bit, non-prefetchable) [size=16K]
	Region 5: Memory at f6c04000 (32-bit, non-prefetchable) [size=8K]
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
	Capabilities: [70] Express (v2) Endpoint, IntMsgNum 0
		DevCap:	MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 75W TEE-IO-
		DevCtl:	CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
			MaxPayload 512 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 16GT/s, Width x4, ASPM L1, Exit Latency L1 <64us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCtl:	ASPM L1 Enabled; RCB 64 bytes, LnkDisable- CommClk+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 16GT/s, Width x4
			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
			 10BitTagComp+ 10BitTagReq- OBFF Via message/WAKE#, ExtFmt- EETLPPrefix-
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS- TPHComp- ExtTPHComp-
			 AtomicOpsCap: 32bit- 64bit- 128bitCAS-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+
			 AtomicOpsCtl: ReqEn-
			 IDOReq- IDOCompl- LTR+ EmergencyPowerReductionReq-
			 10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
		LnkCap2: Supported Link Speeds: 2.5-16GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
		LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+ EqualizationPhase1+
			 EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
			 Retimer- 2Retimers- CrosslinkRes: Upstream Port
	Capabilities: [b0] MSI-X: Enable+ Count=17 Masked-
		Vector table: BAR=0 offset=00002000
		PBA: BAR=0 offset=00003000
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
			ECRC- UnsupReq- ACSViol- UncorrIntErr- BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
			PoisonTLPBlocked- DMWrReqBlocked- IDECheck- MisIDETLP- PCRC_CHECK- TLPXlatBlocked-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
			ECRC- UnsupReq- ACSViol- UncorrIntErr+ BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr- CorrIntErr- HeaderOF-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+ CorrIntErr+ HeaderOF+
		AERCap:	First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
			MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
		HeaderLog: 00000000 00000000 00000000 00000000
	Capabilities: [148 v1] Virtual Channel
		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=1
		Arb:	Fixed+ WRR32+ WRR64+ WRR128+
		Ctrl:	ArbSelect=Fixed
		Status:	InProgress-
		Port Arbitration Table [1b8] <?>
		VC0:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
			Arb:	Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
			Ctrl:	Enable+ ID=0 ArbSelect=Fixed TC/VC=01
			Status:	NegoPending- InProgress-
	Capabilities: [1f8 v1] Device Serial Number 00-00-00-01-00-4c-e0-00
	Capabilities: [208 v1] Power Budgeting <?>
	Capabilities: [218 v1] Secondary PCI Express
		LnkCtl3: LnkEquIntrruptEn- PerformEqu-
		LaneErrStat: 0
	Capabilities: [238 v1] Physical Layer 16.0 GT/s <?>
	Capabilities: [25c v1] Lane Margining at the Receiver
		PortCap: Uses Driver-
		PortSta: MargReady+ MargSoftReady+
	Capabilities: [274 v1] Latency Tolerance Reporting
		Max snoop latency: 1048576ns
		Max no snoop latency: 1048576ns
	Capabilities: [27c v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
			  PortCommonModeRestoreTime=60us PortTPowerOnTime=60us
		L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
			   T_CommonMode=0us LTR1.2_Threshold=32768ns
		L1SubCtl2: T_PwrOn=60us
	Capabilities: [28c v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
	Capabilities: [38c v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
	Capabilities: [3c4 v1] Data Link Feature <?>
	Kernel driver in use: nvme
	Kernel modules: nvme
Some fdisk Info:
Disk /dev/nvme3n1: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: KLEVV CRAS C910 M.2 NVMe SSD 4TB
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 6560ED47-9A4F-4352-9C46-B12D78A3041F
Device         Start        End    Sectors  Size Type
/dev/nvme3n1p1    34      32767      32734   16M Microsoft reserved
/dev/nvme3n1p2 32768 7813152767 7813120000  3.6T Microsoft basic data
dmesg nvme block: I believe its nvme0
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-linux-cachyos root=UUID=2c2f2818-a36a-4edc-91b2-a6df63083de0 rw nowatchdog zswap.enabled=0 nvme_load=yes nvme_core.default_ps_max_latency_us=0 nvidia.NVreg_EnableGpuFirmware=0 splash loglevel=3
[    0.042622] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux-cachyos root=UUID=2c2f2818-a36a-4edc-91b2-a6df63083de0 rw nowatchdog zswap.enabled=0 nvme_load=yes nvme_core.default_ps_max_latency_us=0 nvidia.NVreg_EnableGpuFirmware=0 splash loglevel=3
[    0.042655] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-linux-cachyos nvme_load=yes", will be passed to user space.
[    3.238162]     nvme_load=yes
[    5.378883] nvme nvme1: pci function 0000:05:00.0
[    5.378885] nvme nvme2: pci function 0000:06:00.0
[    5.378887] nvme nvme0: pci function 0000:02:00.0
[    5.378888] nvme nvme3: pci function 0000:09:00.0
[    5.412406] nvme nvme1: missing or invalid SUBNQN field.
[    5.418195] nvme nvme1: 15/0/0 default/read/poll queues
[    5.420606] nvme nvme1: Ignoring bogus Namespace Identifiers
[    5.421826]  nvme1n1: p1
[    5.422636] nvme nvme0: D3 entry latency set to 10 seconds
[    5.426498] nvme nvme0: 16/0/0 default/read/poll queues
[    5.429545]  nvme0n1: p1 p2
[    5.483926] nvme nvme2: allocated 64 MiB host memory buffer (1 segment).
[    5.509360] nvme nvme3: allocated 64 MiB host memory buffer (1 segment).
[    5.513901] nvme nvme3: 16/0/0 default/read/poll queues
[    5.521797]  nvme3n1: p1 p2
[    5.523057] nvme nvme2: 8/0/0 default/read/poll queues
[    5.546060] nvme nvme2: Ignoring bogus Namespace Identifiers
[    5.734198] EXT4-fs (nvme0n1p2): mounted filesystem 2c2f2818-a36a-4edc-91b2-a6df63083de0 r/w with ordered data mode. Quota mode: none.
[    6.142619] EXT4-fs (nvme0n1p2): re-mounted 2c2f2818-a36a-4edc-91b2-a6df63083de0 r/w. Quota mode: none.
[    7.152161] BTRFS: device label StorageNVMe devid 1 transid 326 /dev/nvme2n1 (259:8) scanned by mount (719)
[    7.153046] BTRFS: device label GamesNVMe2 devid 1 transid 100 /dev/nvme1n1p1 (259:1) scanned by mount (718)
[    7.153453] BTRFS info (device nvme2n1): first mount of filesystem e3682e1d-ca3f-4543-989a-da86d2bf0044
[    7.153465] BTRFS info (device nvme2n1): using crc32c (crc32c-intel) checksum algorithm
[    7.153636] BTRFS info (device nvme1n1p1): first mount of filesystem 093fc491-866d-4632-b6e7-91c4f30013a7
[    7.153638] BTRFS info (device nvme1n1p1): using crc32c (crc32c-intel) checksum algorithm
[   19.333266] nvme nvme0: using unchecked data buffer
[   19.399823] block nvme3n1: No UUID available providing old NGUID
More info to come no doubt.
When drive fails to initialize under Linux, and thus will be excluded from system devices entirely, the following error is in dmesg.
[ 3.272061] nvme nvme3: pci function 0000:09:00.0
[ 23.304409] nvme nvme3: Device not ready; aborting reset, CSTS=0x1
This does not appear to be related to power management apst issue like many other NVMe have been hit with and is not patched in kernel to resolve.
Reference: Solid state drive/NVMe - ArchWiki
In this state, typically if I soft boot with grub into Windows 11 I will have the drive missing there also (Put into a failed state by Linux for some reason)
A Cold Boot / Hard Reset usually kicks it out of this state and Windows 11 can then see it again.
PS. Because I didn’t build my own kernel I can’t post on BugZilla atm. However I have tested several arch distro kernels and the issue is universal. The next thing to test to see if non-arch distro’s have this issue.
I do not believe compiling my own kernel will help because this is intermittent and not straight up failure to work.
BIG UPDATE:
SO I have discovered this is actually a regression in the CACHYOS Kernel that causes this particular NVMe drive to not initialize correctly majority of the time.
Booting to windows11 beforehand does allow it to initialize normally in cachyos-kernel; but won’t without.
I also discover the mainline arch kernel is unaffected and drive works fine, and I’d presume -zen kernel is likely to also work but that doesn’t matter atm.
UPDATE: I believe the mainline Arch kernel just causes the issue to happen less often but overall still has the issue.
Going to open up a new linux kernel bug report soon.
This is unlikely to lead anywhere since its not a wide spread issue, perhaps I’m the only person using this drive under Linux since it is one of those NEW brands.
https://bugzilla.kernel.org/show_bug.cgi?id=219916
This still comes back every few months and stays a long time. Seems to be related to kernel updates.
Unfixable it seems as nobody else has this issue with KLEVV drives as apparently I was only one on planet earth that bought a 4tb and uses it for Linux. Cool.
Hey buddy, you’re definitely not alone. In fact, I think I’m even luckier than you—I bought four of those 4 TB drives. And I only use Linux. How’s that? I’m almost about to lose my mind…lol….
your having issues with them?
So what I did in the end is just put the 4TB in a USB4 (only have 10Gbps port atm) nvme case and use it as my storage drive since my 2TB storage drive was running out of room (its nvme so I just reverse role).
PS. Yes the USB4 case bypasses the detection issue under Linux.
If you get time I’d try and submit info in the Kernel bug report I did a while ago for these drives, its basically stale atm, a patch attempt was made but the issue I believe goes beyond just detection timings, its a actual compatibility issue with controller, IMO.
I also have one of the SSDs and having issues. 6.17.2-2 kernel, using Proxmox though. It wouldn’t initialise in my PCIe 3.0 slots, so I installed into a PCIe 2.0 slot and that worked, but after 5 days of uptime it just dropped off. Very odd, it behaved fine in Windows on another system, so I don’t think my drive is “bad”.
Yep that is what the KLEVV drives do, they just randomly drop-off from initializing under Linux. Sometimes it happens right after updating and rebooting.
same issue here, also with Ubuntu: KLEVV 1TB, completely bricked after 1 month of usage. Avoid this brand
Interesting enough I thought my 4TB drive was bricked after a small mishap with a NVMe USB key drive. Sent it back to the STORE and well it came back to life…
Weirdest shit ever. Still using it now without issue via a USB4 adapter.
it is probably a faulty firmware. I also noticed the system slowing down, ie mouse lagging, even at bios level, and also while testing the SSD drives with Gigabyte’s bios utility compared with another Lexar drive I have installed in another slot. In my opinion it’s not a Linux kernel issue anymore, just a faulty batch. The bios often crashes even by selecting the drive for inspection.
I’ve not had that issue. I think perhaps you do actually have a faulty drive.
The issue with my USB4 Adapter was I plugged in a 12v power source instead of a 5v! So it was definitely that which caused my drive to drop dead for a while.
Just surprised it recovered. I managed to get my money back for the USB4 Adapter, pretended it just died.. I mean it had a faulty fan anyway so why not :slight_smile:
Anyway I’m going to use my 4TB KLEVV for this Intel ARC Nuc I have and see if CachyOS boots reliably off it or if the kernel complains it can’t find anything.. That would be weird if so.
I haven’t had any detected faults with the KLEVV otherwise. Just that initial compatibility issue with Linux which is apparently fixed now in upstream patches.
It also may be related to my AM5 ASUS motherboard combo I’m using atm.
And as always, not a single issue with USB4 adapter. (only my NUC can do USB4 speeds tho)
Same DEVICE NOT READY issue on Intel NUC.
Presumably PCI port reset for the device will work but I need this solved for Linux so I can use the drive normally.
PS. A lot of people reporting these devices as bricked are using Linux which gets stuck in the device not ready state but if they boot them into Windows they’ll discover the drive often works.
PCI port reset steps here: https://www.reddit.com/r/linuxquestions/comments/1pv2t9v/temporary_workaround_nvme_not_detected_on_linux/
NOT particularly useful if you want this as a boot device.
