Intermittent audio in CachyOS
Hello all,
I’ve been trying to troubleshoot this but to no avail.
Recently, I noticed that the audio in CachyOS has been intermittent. When I try to adjust the volume, I don’t get audio feedback like I usually do. If I keep at it (maybe 5-10 seconds), it’ll eventually give me audible feedback.
This will happen with apps as well: Brave on Youtube, Zoom … anything that can play back audio. It also happens with any connected devices: HDMI port, headphones, Bluetooth speakers, et cetera, so the problem persists.
I’ve tried switching to the “Pro Audio” (Meteor Lake driver, I believe) but that doesn’t work at all, not even the microphone. At least on the “hi-fi quality” setting, the microphone appears to work, and the audio “appears” to work, meaning you can see movement on the audio scale, but the audio is not present.
What else I’ve tried:
Switching to the LTS kernel; no joy.
Tried the new 7.x (I don’t remember what it is now) kernel.
Rolled back to a BTRFS snapshot that I knew it was working on; no joy.
Changed DEs. The interesting thing about this is in the COSMIC desktop (I wanted to try that out) is that it would continually switch it over to a different input. I suspect that maybe the same could be happening in my current DE (Plasma), but it doesn’t appear to be the case with the GUI. But the audio WAS working flawlessly in KDE for awhile.
Tried blacklisting specific drivers as per various posts on CachyOS forums and Reddit; didn’t work.
Removed config files that may have been corrupted; that didn’t work (those files were related to Pipewire).
Tried to set the Nice (priority) to a higher level; that didn’t work.
A persistent error that I do get whenever I check the status of Pipewire is: mod.rt: could not set nice-level to -11: Permission denied
I tried putting my user in the “rtkit” group, I believe, bit I didn’t see it in my list. I didn’t create it to see if that would solve the problem.
Hardware: Asus Vivobook S (S 15 5506M)
Kernel: CachyOS 7.0.1-1s
I did run the cachyOS bugreport script but I wasn’t quite sure what you were looking for on that, so I opted not to paste the whole thing, but I’ll post what I think might be useful below:
I typically don’t have problems with audio; it’s usually always wi-fi!
Thanks in advance for your help!
Start of CachyOS bug report log file. Please send this report,
along with a description of your bug, to CachyOS.
Date: Tue Apr 28 09:24:50 EDT 2026
uname: Linux 7.0.1-1-cachyos #1 SMP PREEMPT Thu, 23 Apr 2026 21:04:50 +0000 x86_64 GNU/Linux
cmdline: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos root=UUID=d9e8111b-23c7-424f-98f8-45dc8b6ba410 rw rootflags=subvol=@ nowatchdog nvme_load=YES zswap.enabled=0 splash loglevel=3
Getting Hardware Information
System:
Kernel: 7.0.1-1-cachyos arch: x86_64 bits: 64 compiler: clang v: 22.1.3
clocksource: tsc avail: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos
Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Distro: CachyOS base: Arch Linux
Machine:
Type: Laptop System: ASUSTeK product: ASUS Vivobook S 15 S5506MA_S5506MA
v: 1.0 serial:
Mobo: ASUSTeK model: S5506MA v: 1.0 serial:
uuid: fa98b6dc-6ab0-8e4f-bc26-6bb529454f38 Firmware: UEFI vendor: American
Megatrends LLC. v: S5506MA.318 date: 02/25/2025
Battery:
ID-1: BAT0 charge: 67.7 Wh (100%) condition: 67.7/75 Wh (90.3%) volts: 17.43
min: 16.03 model: AS3GYYg3KC U340646 type: Unknown serial:
charging: status: full control: start: N/A end: 100% cycles: N/A
CPU:
Info: model: Intel Core Ultra 7 155H socket: U3E1 bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1684 min/max: 400/4500:4800:3800:2500
base/boost: 4158/4800 scaling: driver: intel_pstate governor: powersave
volts: 1.0 V ext-clock: 100 MHz cores: 1: 1684 2: 1684 3: 1684 4: 1684
5: 1684 6: 1684 7: 1684 8: 1684 9: 1684 10: 1684 11: 1684 12: 1684
13: 1684 14: 1684 15: 1684 16: 1684 17: 1684 18: 1684 19: 1684 20: 1684
21: 1684 22: 1684 bogomips: 131788
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: ghostwrite status: Not affected
Type: indirect_target_selection status: Not affected
Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data status: Not affected
Type: old_microcode status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: retbleed status: Not affected
Type: spec_rstack_overflow status: Not affected
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Type: srbds status: Not affected
Type: tsa status: Not affected
Type: tsx_async_abort status: Not affected
Type: vmscape mitigation: IBPB before exit to userspace
Graphics:
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
built: 2023+ ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:7d55 class-ID: 0300
Device-2: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:2 chip-ID: 3277:0060
class-ID: fe01 serial:
Display: unspecified server: X.Org v: 24.1.10 with: Xwayland v: 24.1.10
compositor: kwin_wayland driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2880x1620 s-dpi: 96 s-size: 762x428mm (30.00x16.85")
s-diag: 874mm (34.41") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: Samsung 0x416e built: 2021 res: 2880x1620 dpi: 213
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 2880x1620
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.5-arch2.4
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 14.75 GiB unified: yes
API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: Intel
Arc Graphics (MTL) driver: mesa intel v: 26.0.5-arch2.4
device-ID: 8086:7d55 surfaces: N/A
de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdpyinfo,xprop
Audio:
Device-1: Intel Meteor Lake-P HD Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-mtl
alternate: snd_sof_pci_intel_mtl,snd_hda_intel bus-ID: 0000:00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
API: ALSA v: k7.0.1-1-cachyos status: kernel-api
Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
Server-2: JACK v: 0.126.0 status: off tools: N/A
Server-3: PipeWire v: 1.6.4 status: n/a (root, process) with:
1: pipewire-pulse status: active 2: wireplumber status: active
3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Network:
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:7e40 class-ID: 0280
IF: wlan0 state: up mac:
IF-ID-1: docker0 state: down mac:
Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 7c010c
This might be of interest:
6.088913] sof-audio-pci-intel-mtl 0000:00:1f.3: Booted firmware version:
[ 6.101886] sof-audio-pci-intel-mtl 0000:00:1f.3: loading topology: intel/sof-ipc4-tplg/sof-hda-generic-2ch.tplg
[ 6.101933] sof-audio-pci-intel-mtl 0000:00:1f.3: Topology: ABI 3:29:1 Kernel ABI 3:23:1
[ 6.102114] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[ 6.121706] snd_hda_codec_alc269 ehdaudio0D0: autoconfig for ALC294: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 6.121711] snd_hda_codec_alc269 ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 6.121713] snd_hda_codec_alc269 ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 6.121715] snd_hda_codec_alc269 ehdaudio0D0: mono: mono_out=0x0
[ 6.121716] snd_hda_codec_alc269 ehdaudio0D0: inputs:
[ 6.139924] iwlwifi 0000:00:14.3: base HW address:
[ 6.182971] typec port0: bound usb3-port2 (ops connector_ops)
[ 6.182982] typec port0: bound usb2-port1 (ops connector_ops)
[ 6.182987] typec port0: bound usb4_port1 (ops connector_ops.llvm.12704628839795162181 [thunderbolt])
[ 6.285881] systemd-journald[607]: Received client request to flush runtime journal.
[ 6.291605] systemd-journald[607]: /var/log/journal/2ae0fd0c085a41609ddcba11f464c696/system.journal:
HDMI converter 3
[ 6.482149] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input10
[ 6.482206] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input11
[ 6.482252] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input12
[ 6.482294] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input13
[ 6.483723] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.483725] Bluetooth: BNEP filters: protocol multicast
[ 6.483733] Bluetooth: BNEP socket layer initialized
[ 6.706892] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 6.706904] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 6.706911] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x80
[ 6.706918] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 6.707652] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 6.992703] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 6.992722] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 6.992729] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x80
[ 6.992737] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 6.993563] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 7.104775] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your
Not sure what this is all about.
pr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/2/cwd”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/1/cwd”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/2/root”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/2/exe”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/1/root”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/1/exe”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/3/cwd”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/3/root”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/3/exe”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/4/cwd”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/4/root”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/4/exe”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/5/cwd”
Apr 27 19:48:53 kioworker[3476]: readlink failed! “/proc/5/root”
Hello there. Did you check your Intel PCI audio messages using journalctl , with command : journalctl -b and look for your sof-audio-pci-intel-apl firmware messages ? Maybe there is a situation with the generic sound Sof linux driver and your card adapter.
I had a similar issue once with this.
Mai 12 09:43:39 sss-mini kernel: sof-audio-pci-intel-apl 0000:00:0e.0: Firmware info: version 2:2:0-57864
Mai 12 09:43:39 sss-mini kernel: sof-audio-pci-intel-apl 0000:00:0e.0: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
Mai 12 09:43:39 sss-mini kernel: sof-audio-pci-intel-apl 0000:00:0e.0: unknown sof_ext_man header type 3 size 0x30
Mai 12 09:43:39 sss-mini kernel: sof-essx8336 sof-essx8336: quirk mask 0x2
Mai 12 09:43:39 sss-mini kernel: sof-essx8336 sof-essx8336: quirk SSP2
Mai 12 09:43:39 sss-mini kernel: sof-audio-pci-intel-apl 0000:00:0e.0: Topology: ABI 3:22:1 Kernel ABI 3:23:0
Mai 12 09:43:39 sss-mini kernel: sof-essx8336 sof-essx8336: ASoC: Parent card not yet available, widget card binding deferred
THANK YOU!!!
I’m not sure that this was necessarily the solution to my problem but it did lead me down another rabbit hole and I ended up fixing the problem.
What I ended up doing was making the “alsa.conf” file in /etc/modprobe.d directory, and in that file added:
“options snd-intel-dspcfg dsp_driver=1”
I’m nto sure if it’s the best or cleanest workaround, but it persists upon reboot, closing the laptop lid, etc.
What I don’t know is if it will work with Bluetooth speakers or headphones, but that’s not overly critical at this point.
Thanks again!
