Looks to be an issue in installing the OS as well with this package.
:: Replace zlib with cachyos-v4/zlib-ng-compat? [Y/n]
resolving dependencies...
warning: cannot resolve "zlib-ng-compat=2.2.2", a dependency of "lib32-zlib-ng-compat"
warning: cannot resolve "zlib-ng=2.2.2", a dependency of "lib32-zlib-ng"
warning: cannot resolve "lib32-zlib-ng", a dependency of "lib32-zlib-ng-compat"
warning: cannot resolve "lib32-zlib", a dependency of "lib32-mesa"
warning: cannot resolve "lib32-zlib", a dependency of "lib32-opencl-rusticl-mesa"
warning: cannot resolve "lib32-zlib", a dependency of "lib32-vulkan-intel"
:: The following packages cannot be upgraded due to unresolvable dependencies:
lib32-mesa lib32-opencl-rusticl-mesa lib32-vulkan-intel lib32-zlib-ng-compat
:: Do you want to skip the above packages for this upgrade? [y/N] error: failed to prepare transaction (could not satisfy dependencies)
:: unable to satisfy dependency 'zlib-ng-compat=2.2.2' required by lib32-zlib-ng-compat
:: unable to satisfy dependency 'zlib-ng=2.2.2' required by lib32-zlib-ng
:: unable to satisfy dependency 'lib32-zlib-ng' required by lib32-zlib-ng-compat
:: unable to satisfy dependency 'lib32-zlib' required by lib32-mesa
:: unable to satisfy dependency 'lib32-zlib' required by lib32-opencl-rusticl-mesa
:: unable to satisfy dependency 'lib32-zlib' required by lib32-vulkan-intel
.. Running QList("pacman", "-Su", "--noconfirm", "--disable-download-timeout")
.. Target cmd: QList("pacman", "-Su", "--noconfirm", "--disable-download-timeout") Exit code: 1 output:
warning: glibc: local (2.41+r6+gcf88351b685d-1) is newer than cachyos-v4 (2.41+r2+g0a7c7a3e283a-2)
warning: lib32-glibc: local (2.41+r6+gcf88351b685d-1) is newer than cachyos-v4 (2.41+r2+g0a7c7a3e283a-2)
:: Replace lib32-zlib with cachyos-v4/lib32-zlib-ng-compat? [Y/n] warning: python: local (3.13.2-1) is newer than cachyos-v4 (3.13.1-2)
WARNING: [PYTHON JOB]: "Command 'pacman' returned non-zero exit status 1."
[PYTHON JOB]: "stdout::: Starting full system upgrade...\nwarning: glibc: local (2.41+r6+gcf88351b685d-1) is newer than cachyos-v4 (2.41+r2+g0a7c7a3e283a-2)\nwarning: lib32-glibc: local (2.41+r6+gcf88351b685d-1) is newer than cachyos-v4 (2.41+r2+g0a7c7a3e283a-2)\n:: Replace lib32-zlib with cachyos-v4/lib32-zlib-ng-compat? [Y/n] warning: python: local (3.13.2-1) is newer than cachyos-v4 (3.13.1-2)\n\n:: Replace zlib with cachyos-v4/zlib-ng-compat? [Y/n] \nresolving dependencies...\nwarning: cannot resolve \"zlib-ng-compat=2.2.2\", a dependency of \"lib32-zlib-ng-compat\"\nwarning: cannot resolve \"zlib-ng=2.2.2\", a dependency of \"lib32-zlib-ng\"\nwarning: cannot resolve \"lib32-zlib-ng\", a dependency of \"lib32-zlib-ng-compat\"\nwarning: cannot resolve \"lib32-zlib\", a dependency of \"lib32-mesa\"\nwarning: cannot resolve \"zlib-ng-compat=2.2.2\", a dependency of \"lib32-zlib-ng-compat\"\nwarning: cannot resolve \"zlib-ng=2.2.2\", a dependency of \"lib32-zlib-ng\"\nwarning: cannot resolve \"lib32-zlib-ng\", a dependency of \"lib32-zlib-ng-compat\"\nwarning: cannot resolve \"lib32-zlib\", a dependency of \"lib32-opencl-rusticl-mesa\"\nwarning: cannot resolve \"zlib-ng-compat=2.2.2\", a dependency of \"lib32-zlib-ng-compat\"\nwarning: cannot resolve \"zlib-ng=2.2.2\", a dependency of \"lib32-zlib-ng\"\nwarning: cannot resolve \"lib32-zlib-ng\", a dependency of \"lib32-zlib-ng-compat\"\nwarning: cannot resolve \"lib32-zlib\", a dependency of \"lib32-vulkan-intel\"\nwarning: cannot resolve \"zlib-ng-compat=2.2.2\", a dependency of \"lib32-zlib-ng-compat\"\nwarning: cannot resolve \"zlib-ng=2.2.2\", a dependency of \"lib32-zlib-ng\"\nwarning: cannot resolve \"lib32-zlib-ng\", a dependency of \"lib32-zlib-ng-compat\"\n:: The following packages cannot be upgraded due to unresolvable dependencies:\n lib32-mesa lib32-opencl-rusticl-mesa lib32-vulkan-intel lib32-zlib-ng-compat\n\n:: Do you want to skip the above packages for this upgrade? [y/N] error: failed to prepare transaction (could not satisfy dependencies)\n\n:: unable to satisfy dependency 'zlib-ng-compat=2.2.2' required by lib32-zlib-ng-compat\n:: unable to satisfy dependency 'zlib-ng=2.2.2' required by lib32-zlib-ng\n:: unable to satisfy dependency 'lib32-zlib-ng' required by lib32-zlib-ng-compat\n:: unable to satisfy dependency 'lib32-zlib' required by lib32-mesa\n:: unable to satisfy dependency 'zlib-ng-compat=2.2.2' required by lib32-zlib-ng-compat\n:: unable to satisfy dependency 'zlib-ng=2.2.2' required by lib32-zlib-ng\n:: unable to satisfy dependency 'lib32-zlib-ng' required by lib32-zlib-ng-compat\n:: unable to satisfy dependency 'lib32-zlib' required by lib32-opencl-rusticl-mesa\n:: unable to satisfy dependency 'zlib-ng-compat=2.2.2' required by lib32-zlib-ng-compat\n:: unable to satisfy dependency 'zlib-ng=2.2.2' required by lib32-zlib-ng\n:: unable to satisfy dependency 'lib32-zlib-ng' required by lib32-zlib-ng-compat\n:: unable to satisfy dependency 'lib32-zlib' required by lib32-vulkan-intel\n:: unable to satisfy dependency 'zlib-ng-compat=2.2.2' required by lib32-zlib-ng-compat\n:: unable to satisfy dependency 'zlib-ng=2.2.2' required by lib32-zlib-ng\n:: unable to satisfy dependency 'lib32-zlib-ng' required by lib32-zlib-ng-compat"
[PYTHON JOB]: "stderr:None"
09:00:52 [6]: virtual void Calamares::JobThread::run()
Skipping non-emergency job "Configuring LUKS key file."
.. Skipping non-emergency job "Configuring encrypted swap."
.. Skipping non-emergency job "fstab"
.. Skipping non-emergency job "plymouthcfg"
.. Skipping non-emergency job "zfshostid"
.. Skipping non-emergency job "initcpiocfg"
.. Skipping non-emergency job "Creating initramfs with mkinitcpio…"
.. Skipping non-emergency job "Configuring <pre>sudo</pre> users…"
.. Skipping non-emergency job "Preparing groups…"
.. Skipping non-emergency job "Create user khyber"
.. Skipping non-emergency job "Set password for user khyber"
.. Skipping non-emergency job "Set password for user root"
.. Skipping non-emergency job "Set hostname babylon5"
.. Skipping non-emergency job "networkcfg"
.. Skipping non-emergency job "displaymanager"
.. Skipping non-emergency job "hwclock"
.. Skipping non-emergency job "Remove unneeded ucode"
.. Skipping non-emergency job "bootloader"
.. Skipping non-emergency job "reset 90-mkinitcpio-install.hook"
.. Skipping non-emergency job "services-systemd"
.. Skipping non-emergency job "Running shell processes…"
.. Skipping non-emergency job "Enable systemd boot manager for automatic boot entry generation"
.. Skipping non-emergency job "Enable the UFW Firewall as default and allow outgoing but deny incoming"
.. Starting EMERGENCY JOB "Unmounting file systems…" ( 46 / 46 )
09:00:52 [6]: Calamares::JobResult unmountTargetMounts(const QString&)
Read 13 entries from "/tmp/calamares-root-2eqrloxc/"
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/var/tmp")
.. Running QList("udevadm", "settle")
.. Running QList("sync")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/var/log")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/var/cache")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/sys/firmware/efi/efivars")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/sys")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/srv")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/run/udev")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/run")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/root")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/proc")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/home")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/dev")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc/boot")
.. Running QList("umount", "-lv", "/tmp/calamares-root-2eqrloxc")
09:00:53 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
ERROR: Installation failed: "Package Manager error"
.. - message: "Package Manager error"
.. - details: The package manager could not update the system. The command <pre>pacman</pre> returned error code 1.
09:00:53 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
Calamares will quit when the dialog closes.
09:00:53 [6]: DEBUG (Qt): QML Component (default slideshow) deactivated
09:00:53 [6]: void Config::doNotify(bool, bool)
Notification not sent; completion: failed
09:00:53 [6]: void {anonymous}::PowerManagementInterface::uninhibitSleep()
Sleep was never inhibited.
09:01:21 [6]: void Config::doRestart(bool)
mode= "never" user wants restart? false force restart? false
[liveuser@CachyOS ~]$
Hope this log helps.
