I was told to put the results of a command that shows my drives info. I hope this is the right place:
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 850
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 8666AC67-BCFE-4F2A-B002-FA9DE6FFBC82
Device Start End Sectors Size Type
/dev/sda1 34 2081 2048 1M Microsoft reserved
/dev/sda2 8392704 976773095 968380392 461.8G Linux filesystem
/dev/sda3 4096 8392703 8388608 4G EFI System
Partition table entries are not in disk order.
Disk /dev/nvme0n1: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 970 EVO Plus 500GB
Disklabel type: gpt
Disk identifier: 91709CD3-8C68-4939-9720-E7719E0E1763
/dev/nvme0n1p1 2048 34815 32768 16M Microsoft reserved
/dev/nvme0n1p2 34816 975265791 975230976 465G Microsoft basic data
/dev/nvme0n1p3 975265792 976771071 1505280 735M Windows recovery environment
Disk /dev/nvme1n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: WDC PC SN530 SDBPNPZ-1T00-1006
Disklabel type: gpt
Disk identifier: 21903845-170A-412A-B212-CBBA319FD278
/dev/nvme1n1p1 34 2081 2048 1M Microsoft reserved
/dev/nvme1n1p2 8392704 2000409191 1992016488 949.9G Linux filesystem
/dev/nvme1n1p3 4096 8392703 8388608 4G EFI System
Disk /dev/zram0: 15.52 GiB, 16661872640 bytes, 4067840 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
TY for any help you give.
I used to boot from the 970 so I hope it still has the boot files. The linux install is on the 850 which had the boot files. The other drive is my backup drive.
