This thread is only for info, so nobody with fancy liquid coolers can’t make use of their expensive hardware. If any of you already updated, you can install a 6.10 kernel meanwhile it gets fixed.
It works fine for me.
My Aquacomputer Pump is working fine.
Water Temp, PWM, Profiles.
