Hi.
I seened to have messed up a few things here…úps
I tried to get jack working, to use my USB Soundcard with my DAW (reaper).
But when I started jack all sounds from other applications, also system were gone. I tried to get a jack sink running, but that didn’t work out.
At some point everything got so bugged, that chachyos didn’t boot anymore.
Thanks for the snapshots I could revert some things I messed up.
But now I have this weird situation, that the sound only works, if I manually (in the system settings, I think it’s pavucontrol) disable my soundcard and enable it again.
But I have to do that every time another application wants to play some audio.
Also, the ProAudio option vanished from the drop down menu.
Also, if the Soundcard is inactive/off, the correct name is shown. When I activate it’s just named playback/recording devices.
So, my question right now is: Can I maybe just reset everything (or preferably just the audio part) to it’s fresh-installation state?
