Hello everyone!
so i made a mistake and was forced to do a reinstall, i didn’t format my /home and user files, after the reinstall i enabled bluetooth from cachyos hello, and for some reason i turned the bluetooth on and off multiple times back to back, then clicked on shutdown but the window that says “the system will power off automatically in 60 seconds” never came, so i force-shutdowned the system, now the system randomly logs-out.
pls help me i don’t like to do another reinstall
Here is the link made by running ‘sudo cachyos-bugreport.sh’:
