I created/edited a theme for GRUB
Hello, I edited a GRUB theme made for Arch Linux to match CachyOS, hope you like it!
wow i rlly like the theme.
since you said you are a beginner and i’m a total newbie i wont take the risk to try it, but it is visually really appealing !
edit : i guess it would be cool to have a readme that include this screenshot on the github page.
I have tested the installation several times both on a virtual machine and on my PC system, and I have had no problems.
You can test it on a virtual machine first.
I will add this information to Github later.
I updated Github and simplified the installation process.
Please use this for the default theme
Can you also update the description on the GitHub to English
Done! Thanks for the suggestion.
I updated the theme, added the CachyOS icon to the selection menu, the penguin icon is for distros that are not in the theme file.
Nice thank
