HP Omen – Stutter/FPS issues on external monitor under Wayland (CachyOS/KDE Plasma 6)
Hardware
  • HP Omen Notebook
  • Intel Raptor Lake UHD Graphics (iGPU) + NVIDIA RTX 4070 Max-Q (dGPU)
  • External monitor via HDMI, 2560x1440
Symptoms
  • Desktop animations stutter on external monitor (visible drag when moving windows)
  • FPS issues in games on external monitor
  • Integrated laptop display was perfectly smooth
  • Problem persisted across different refresh rate combinations (60/120/144/240Hz)
  • Toggling compositor on/off (Alt+Shift+F12) made no difference
Root cause
  • BIOS setting “Graphics switch” was set to “NVIDIA Advanced Optimus”
  • This mode is poorly supported under Linux
  • Result: The HDMI port was driven by the Intel GPU, while the laptop display was driven by the NVIDIA GPU (unusual, typically the other way around)
  • KWin/compositor was rendering via the Intel GPU (OpenGL renderer: Mesa Intel(R) Graphics)
  • The Intel driver caused the stuttering on the external monitor
Diagnosis
# Showed: HDMI connected to Intel (card1), laptop display connected to NVIDIA (card2)
bash -c 'for card in /sys/class/drm/card*-*; do echo "$(basename $card): $(cat $card/status 2>/dev/null)"; done'
# Showed: KWin rendering via Intel instead of NVIDIA
qdbus6 org.kde.KWin /KWin supportInformation | grep "renderer"
Solution
  1. Enter BIOS
  2. Configuration → Graphics switch → change from “NVIDIA Advanced Optimus” to “Discrete Graphics”
  3. Save and reboot
Result
  • Only NVIDIA GPU active (lspci -k | grep -A 3 -i vga shows only NVIDIA)
  • KWin rendering via NVIDIA (OpenGL renderer: NVIDIA GeForce RTX 4070 Laptop GPU)
  • No more stutter, testufo shows correct frame rates
  • All monitors running on a single GPU
Tradeoff
  • Higher power consumption on battery (NVIDIA GPU always active)
What did NOT help
  • KWIN_DRM_DEVICES environment variable (did not change actual rendering GPU)
  • Matching refresh rates (60Hz/120Hz combination)
  • Disabling Adaptive Sync (marginally better, but not a fix)
