I’ve been having problems with my Thrustmaster pedals in CachyOS. They work fine in debian based systems but I couldn’t even ‘see’ them in CachyOS.
Forget xinput and libinput - they don’t help and libinput only recognises a few input things.
Get evtest from the repo and then run:
sudo evtest and that will list all input devices found. in my case:
o device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: Power Button
/dev/input/event1: Power Button
/dev/input/event10: HDA NVidia HDMI/DP,pcm=9
/dev/input/event11: HDA Intel PCH Rear Mic
/dev/input/event12: HDA Intel PCH Front Mic
/dev/input/event13: HDA Intel PCH Line
/dev/input/event14: HDA Intel PCH Line Out
/dev/input/event15: HDA Intel PCH Front Headphone
/dev/input/event16: Thrustmaster T-Rudder
/dev/input/event17: Logitech Logitech Extreme 3D
/dev/input/event2: Logitech USB Optical Mouse
/dev/input/event3: Logitech Wireless Keyboard PID:4023
/dev/input/event4: Logitech Wireless Mouse
/dev/input/event5: PC Speaker
/dev/input/event6: HP WMI hotkeys
/dev/input/event7: HDA NVidia HDMI/DP,pcm=3
/dev/input/event8: HDA NVidia HDMI/DP,pcm=7
/dev/input/event9: HDA NVidia HDMI/DP,pcm=8
You have the option to select the device and are able to test the inputs onscreen - no fancy graphics, just a text display but you can see what is working and the default limits etc. CTRL-C to exit.
Then just do this: sudo chmod 0666 /dev/input/eventX - where X is the device number.
The event number may not be constant. It will remain the same until a reboot or unplugging of the device. Not tested thoroughly on CachyOS but that is the case on Debian/Mint/Pop!_OS.
This worked for me running the Plasma desktop on X11. I don’t know if it works on Wayland as I haven’t tried it yet. I use the pedals in flight mode in X-Plane-12.
