How to push more power to nvidia laptop gpu
Hi all…linux noob here.
It seems my nvidia gpu is not getting the power it should and as a result fps are lower
sudo nvidia-smi -q -d POWER
==============NVSMI LOG==============
Timestamp                                 : Wed Sep  4 09:34:18 2024
Driver Version                            : 560.35.03
CUDA Version                              : 12.6
Attached GPUs                             : 1
GPU 00000000:01:00.0
    GPU Power Readings
        Power Draw                        : 16.61 W
        Current Power Limit               : 80.00 W
        Requested Power Limit             : N/A
        Default Power Limit               : 80.00 W
        Min Power Limit                   : 1.00 W
        Max Power Limit                   : 105.00 W
    Power Samples
        Duration                          : Not Found
        Number of Samples                 : Not Found
        Max                               : Not Found
        Min                               : Not Found
        Avg                               : Not Found
    GPU Memory Power Readings
        Power Draw                        : N/A
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
sudo nvidia-smi -pl 95
Changing power management limit is not supported in current scope for GPU: 00000000:01:00.0.
All done.
So it doesn’t do anything.
I’m on KDE Plasma 6.1.4 & WM: KWin (Wayland). And yes I have set the power to performance in KDE’s setting.
Hopefully someone can shed some light on how to increase the power limit :slight_smile:
Sure thing
❯ pacman -Qs nvidia
local/egl-wayland 4:1.1.16-1.1
    EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-2
    Nvidia VDPAU library
local/lib32-nvidia-utils 560.35.03-3
    NVIDIA drivers utilities (32-bit)
local/lib32-opencl-nvidia 560.35.03-3
    OpenCL implemention for NVIDIA (32-bit)
local/libva-nvidia-driver 0.0.12-1.1
    VA-API implementation that uses NVDEC as a backend
local/libvdpau 1.5-3.1
local/libxnvctrl 560.31.02-1
    NVIDIA NV-CONTROL X extension
local/linux-cachyos-nvidia-open 6.10.8-2
    nvidia open modules of 560.35.03 driver for the linux-cachyos kernel
local/nvidia-prime 1.0-5
    NVIDIA Prime Render Offload configuration and utilities
local/nvidia-settings 560.31.02-1
    Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 560.35.03-4
local/opencl-nvidia 560.35.03-4
Now I don’t know if it’s weird or not…when I connect my laptop to my TV, which is a 77 inc LG C1, then somehow the power draw is around 85w to 94w << still below the max 105W on the maxQ 3080 this laptop has. And yeah performance is well below compared to what I saw in w11…still I prefer cachy to some spyware os.
You can not do anything there, thats a nvidia issue and there are several reports about this in their forum
GWE like the other main nvidia tools is x11 only.
Thanks everyone for your input. Yeah well I’m still not going back to spyware11…I do my actual work on cachyos and on my other one I just game…m$ can spy as much as they want getting game screenshots.
And frankly having a low wattage pull the overall laptop remains cooler and overall fps also seems better than watching it yoyo.
Guess I’ll just wait it out :slight_smile:
