How to properly join an Arch‑based Linux client (CachyOS) to Active Directory?
Hi everyone,
I’m trying to join a fresh CachyOS (Arch‑based) installation to my Active Directory domain, but I keep running into problems. On other distros (Ubuntu, Fedora, RHEL) this usually takes a few minutes, but on Arch it seems much more complicated.
Here’s what I want to achieve:
  • Join the Linux machine to my AD domain
  • Use SSSD for authentication
  • Allow domain users to log in
  • Have a working /etc/krb5.keytab and a functioning AD backend
What I’ve tried so far:
  • SSSD configuration is valid (sssctl config-check shows no errors)
  • DNS and Kerberos work (SRV records resolve, kinit Administrator works)
  • But SSSD backend stays offline because the machine has no host keytab
  • Arch/CachyOS does not provide adcli or realmd in the official repos
  • Building adcli-git from AUR is difficult because makepkg cannot run as root and PAM/sudo were broken during testing
  • Samba is installed, but I’m not sure if net ads join is the recommended method on Arch for SSSD setups
Main question:
What is the correct and recommended way to join an Arch‑based system to Active Directory so that SSSD can authenticate domain users?
Should I:
  • Use Samba (net ads join) to generate the keytab?
  • Install adcli-git from AUR and use adcli join?
  • Manually create the keytab with ktpass on the Windows DC?
  • Or is there an official Arch method I’m missing?
Any guidance or best practices would be greatly appreciated.
Thanks!
may be this
