Hi Everyone,
I have been using my 2 1440p monitors for while now and happy with the support for 2 moniters, but i have some problems then i try to use my 4k mointer with the 1440p and gaming.
For some reason then i use the 4k moniter with scaling like 150%, the gaming window with fullscreen window / bordersless become some higher resolution. I think the reason its doing that is becuase Xorg witch is used in xwayland, is manpulating the reslotuion then you have scaling enabled. Do anyone have an smart fix for this issue?
im running KDE with wayland on the desktop and that works fine.
