I cant enable fan control in nvidia x server. I tried it on EndeavourOs and it works well. What’s the problem?
if you are on wayland, then nvidia-settings
is useless
no, i swithed to x11
i tried it, nothing is changed. I just install cachyos and didn’t change (or install) anything.
thank for replies. I will try to change kernels.
Changing kernels dont help
