How to auto mount second ssd
Hello. Does anyone know the easiest way to auto mount hard drive everytime i boot up Linux?
Add the UUID and mountpoint to /etc/fstab?
PS.
More info here if needed;
A step-by-step tutorial is also available on CachyOS wiki:
You may choose either of the 2 ways introduced.
Thanks. Wonder why they don’t use method like nobara, just a click and you’re ready to go.
One mistake and you’re screwed. If that happens what you must do?
What one mistake?
If you dont touch any of the important lines already existing then its not really going to be all that bad.. it just wont mount the thing you wanted to. Or similar.
Even if you broke it impressively you could still do what you would do in any other unbootable scenario and chroot or similar.
So screwed level close to 0. Just an extra 5-10 minutes of work if you somehow went out of your way to modify or delete your / line.
