I’m new to Linux, and I am trying to dual boot CachyOS onto my old 2012 Macbook Pro 9,1.
specs:
mid-2012, 15 inch
2.3GHz Quad core Intel i7
16 GB 1600 MHz DDR3
Dual graphics: Intel chip and NVIDIA GeForce GT 650M
1TB SSD
I’m not sure where to begin. I was able to run the install from a bootable USB with an Ethernet connection, and used rEFInd and the default filesystem BTRFS. Install was successful, but when I select CachyOS on the rEFInd menu on bootup, I get a glitchy loading screen and nothing else from CachyOS.
The specifications you provided differ in every respect from those of my MacBook Pro 9,1 (Mid-2012).
I only have an Intel graphics card. I have never used rEFInd, nor do I dual-boot with Windows or OS X.
I would therefore have to do some research myself, but unfortunately, I don’t have the time for that right now.
I appreciate your reply nonetheless. I’m guessing the graphics card could be the issue, but I’m not sure. Could you suggest a way I could move towards a diagnosis for this issue?
I installed Cachy on my MacBook Air 2015 & MacBook Pro 2012 using the Limine bootloader. No dual boot. I wiped the entire SSD on install. I haven’t had any issues.
