Well well, thought I’d say hello and give some kudos to the team behind CachyOS.
I’m a 57 year old long time Linux user, started back in the 90’s when I ran some web hosting servers and tinkered with running it on my desktop throughout the years. I’ve almost always had some form of Linux running somewhere either for hobby or business activities.
Working in IT for a large corporation now which is all MS based so I’m stuck using Windows there. Recently I decided to build a new PC and after experiencing what the Steam Deck has done for Linux gaming I felt it was time to aim at running Linux on it as the only OS.
I started testing Linux Mint on my gaming laptop and everything just worked. When I built my gaming PC though I felt I’d test out some of the more optimized distros and CachyOS pops up as a recommendation.
New system built, load up Cachy and wow is this thing responsive! A couple items weren’t functioning though, for some reason it refuses to load up the ppd for my Brother network printer which Mint finds no problem. I ended up getting the generic ppd to work in Cachy though.
But, seeing as I was having issues with that and some python related stuff (Fooocus, it just don’t work in Arch I find) I tried loading Mint on the new PC. Well, turns out the new PC is a bit more bleeding edge and no bluetooth or wifi working on Mint, loading their 6 series kernel got bluetooth working (sort of) but not the wifi since the new motherboard is using a wifi7 chipset. Didn’t want to waste time with it though since Cachy found it and worked with it. So, back to CachyOS it is.
System is AMD 7800x3D, X670 Pro X motherboard, 64GB RAM, 3TB m.2, Nvidia 4070 Super and wow, does this thing fly under Cachy. Every game I want to try works (some tinkering required on some initially), but I can pretty much just set them to ultimate settings 1440p and play.
Kudos to the team behind this, I’m enjoying the experience so far and donated to keep this going. Especially a big thanks for the Zen4 optimized repository, even more performance!
