Help with kernel update, emergency mode
Hi everyone,
I’m having a persistent issue with kernel updates on CachyOS and I’d really appreciate some help tracking down the root cause.
For the past couple of months, every time I update the kernel and reboot, the system ends up in emergency mode. The update itself completes, but something breaks during boot afterwards.
During the update I consistently get this error related to mkinitcpio:
==> ERROR: Hook 'sd-btrfs-overlayfs' cannot be found
I already removed sd-btrfs-overlayfs from my mkinitcpio hooks and re-generated the initramfs with mkinitcpio -P. The process completes without errors now, but after rebooting the system the same problem reappears and /boot fails to mount.
Here is the relevant error from journalctl -xb -p 3:
usb 3-2.1.2: device descriptor read/64, error -32
zram-generator failed with exit status 1
systemd-modules-load: Failed to find module 'ntsync'
systemd-modules-load: Failed to find module 'uhid'
systemd-modules-load: Failed to find module 'crypto_user'
systemd-modules-load: Failed to find module 'i2c_dev'
systemd-modules-load: Failed to find module 'pkcs8_key_parser'
Failed to start ufw.service
Failed to mount /boot
Timed out waiting for device /dev/zram0
My /etc/fstab looks correct and points to the right partition:
/dev/nvme0n1p1 (vfat, UUID=7AA0-21B7) -> /boot
/dev/nvme0n1p2 (btrfs, UUID=5a532593-8224-4893-8df1-d127536c90b9) -> /
The system works fine otherwise, but any kernel update seems to break the boot process.
What I’ve already tried:
  • Removed sd-btrfs-overlayfs from mkinitcpio hooks
  • Regenerated initramfs (mkinitcpio -P)
  • Verified /etc/fstab
  • Reinstalled kernel packages
  • Checked boot partition integrity
Any guidance would be really appreciated.
Thanks in advance!
can you also report this file
cat /etc/mkinitcpio.conf
and
inxi -Fza
SOLVED: added missing HOOK: base, after that removed sd-btrfs-overlayfs and did sudo pacman -Syu limine-mkinitcpio-hook!
