Im coming from windows and created a boot stick with the file and booted into the CachyOS Installation UI, like the ‘CachyOS Hello’ and wanted to install the OS, then I got some error, im connected to the Internet. I did retry it like 3 times, but with no success.
here’s the log, if it helps
https://termbin.com/dql0
Thanks
Do you use the Erase Disk Option or manual paritoning?
See related log:
2024-06-14 - 12:20:29 [6]: .. Running QList("grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=cachyos", "--force")
2024-06-14 - 12:20:29 [6]: .. Target cmd: QList("grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=cachyos", "--force") Exit code: 1 output:
Installing for x86_64-efi platform.
grub-install: error: failed to make directory: '/boot/efi/EFI/cachyos'.
2024-06-14 - 12:20:29 [2]: WARNING: [PYTHON JOB]: "Command 'grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=cachyos --force' returned non-zero exit status 1."
2024-06-14 - 12:20:29 [6]: [PYTHON JOB]: "stdout:Installing for x86_64-efi platform.\ngrub-install: error: failed to make directory: '/boot/efi/EFI/cachyos'."
2024-06-14 - 12:20:29 [6]: [PYTHON JOB]: "stderr:None"
I did use the option ‘replace a partition’,cause i made a free partition on windows to be replaced.
Is this a BIOS or UEFI System?
A UEFI system, its on a laptop
I think you are running into following issue:
committed 09:34PM - 28 May 24 UTC
This got fixed in kpmcore upstream, but didnt land yet in a release.
Could you try before installing do following:
paru -S kpmcore-git
After that just launch the installer as usual-
That link in your post leads to a 404 page.
